Dedicated HT build: 4 sealed 18" subs + MSO, HTPC-based – multichannel DAC and object-based audio questions
Right now I'm in the process of redoing my whole setup and will go DBA or ART route, so I will only invest time in MSO if those two fail miserably somehow.
I don't care if you use MSO or not. What I do care about is people making claims of fact about it that are so wrong as to be the exact opposite of the truth, as you have done.
Ok, I've provided you with what you have asked. Could you provide measurements of MSO calibration, which show proper time alignment in a way I'm speaking of? If I'm indeed wrong and just misleading people, I will go and redact my post.
can you accommodate an SBA
Speaking of the AVS DIY forum... Maybe a DBA is the way to go.
Front wall
Rear wall
Sure, happy to give any input! With that said, my experience is admittedly rather limited, my objectives and preferences are different, and my room is very different. I've done my best in the past several months to learn about small room acoustics, speakers and subwoofers, treatment, and DSP. I'm primarily interested in music, usually with a very healthy LF boost.
My room not ideal to say the least. It is an odd shape and is full of openings. It's also my living room, so aesthetics and speaker/sub placement are very much a consideration.
-Tide16
-4x Starke Sound SW15 subs
-Buchardt A200 mains running the cardioid tune (cannot treat front wall due to TV and space)
-2ft wide by 6ft tall absorption panels effective down to ~125Hz on left and right wall first reflections
Less than I year ago I ran a simple 2.1 system with Dirac Live RC (no BC or ART). Then I started learning and experimenting. My current speakers and subs are sufficient for the levels I previously listened at, but I now realize that I never liked to listen loud because the sound was terrible. With multiple subs, ART, absorption panels, and the A200 mains limited to 150Hz, I now listen much louder and love it! I'm currently building new subs (4x DIY sealed subs, each with dual opposed Dayton SS15-22 drivers and 2000W) and planning new speakers to allow much more output and lower distortion.
I have measurements, but nothing worth sharing. Part of my learning process has been learning how to measure in a consistent manner and not change too many variables at a time. I can only give you my subjective experience. I set up the fours subs and the Tide16, did the Dirac measurements, loaded a BC filter with a +6dB LF lift. I listened for a couple hours and it was a stunning improvement over anything I previously had. Then I loaded an ART filter also with a +6dB LF lift, and it sounded like there was LESS LF output. Then I changed to a +9dB LF lift and turned the volume up... I was in love. ART removed enough LF ringing to make a very obvious difference to me, and I very much prefer it.
I have no experience Acourate or Audiolense. I have no experience with single or dual bass arrays, but I think I have a correct high-level understanding of how each of them works. I didn't pick up that you were considering a DBA when you mentioned the HTPC option. Yes, my understanding is that ART, Trinnov Waveforming, a DBA, or an SBA with rear absorption are all valid LF decay control methods. I can't speak to which is better generally, or better in your specific situation. Given my room, I think ART is the only option I have.
If I had a dedicated room that was rectangular and not full of openings, I would give serious considerations to the ART alternatives. Do you ever visit the AVS DIY subforum (https://www.avsforum.com/forums/diy-speakers-and-subs.155)? Plenty of guys on that forum that have experience with large DIY subs, DBAs, SBAs, and ART.
I like the simplicity of the Tide16 and ART. The Tide16 also looks nice in my living room. If I had a dedicated room, I'd me more inclined to deal with the extra complexity of the HTPC option. ART is now also available for PC and MacOS. Maybe you build a HTPC and try out ART along with other DSP/DBA options you are considering? Since you have a dedicated room, can you accommodate an SBA (all subs up front with specific SBA placement, and a false rear wall filled with insulation/absorption)?
My understanding and limited experience is that ART mostly cuts, and does not try to fill in deep nulls. So yes, sub placement is still a big factor. That said, I get the impression from my reading about ART that it allows for more flexible sub placement than Waveforming, DBA, or SBA. In my less than ideal room with my sub placement I still have a null in the upper 40's, but it's not very deep. I need to test if placing a sub in one of the ceiling corners would take care of the null. Or maybe the additional output from the DIY subs will help ART to deal with it.
Yes, I would think 4 subs at 1/4 and 3/4 of the width, two front and two back, would be a good layout for ART. I think those positions will properly excite two of the room modes and prevent deep nulls that ART cannot fill.
I don't think I can quantify a headroom reduction with ART. There is the obvious output reduction due to the subs/speakers also outputting out-of-phase sound to reduce LF ringing. Maybe a larger concern is ART having to do lots of cutting to bring down peaks, so as to not have to boost nulls too much. I will say that I'm taking the more is better approach with my DIY subs (8x 15" drivers with lots of excursion and power).
My ART settings are atypical, as I currently have tiny main speakers. To reduce distortion in the mains I set the ART F Support Low value to 149Hz for the mains and the ART F Support High value to 150Hz for the subs. ART does not have a mains to sub crossover like Dirac BC, but I've essentially set ART to do such a crossover. This works as my front subs are co-located with the mains. With larger speakers you would typically you would allow subs to run up to 150Hz and your speakers to run down to a frequency that is appropriate for them, 50Hz for example. In that case ART is using both the subs and mains in that 50-150Hz region to optimize the sound. I don't have experience with multiple larger speakers contributing below 150Hz, but I've read folks reporting excellent results doing so.
If you are interested in infrasonic playback, make sure you read up on the challenges of infrasonic with ART. This honestly might be a deal breaker for ART for you.
There are lots of folks complaining about various things about the Tide16. You can't please everyone, but it might be worth reading the various Tide16 threads to make sure none of those are sticking points for you.
Sorry, that was lots of words, not many clear answers, and no measurement ;-) Hopefully some of it was somewhat helpful.
Thanks a lot for the detailed answer, it was very helpful, especially the point about infrasonic. I would love to use BEQ in a lot for movies, so the 20 Hz high-pass that ART imposes is a serious concern for me. I checked, and as I understand it the "infra bass bypass" lets content below 20 Hz through, but without correction and with a possible bump or dip around the transition.
Some background: the room is dedicated and rectangular (3.0 x 5.8 x 2.7 m), and I'm planning 4 sealed subs with 18" BMS drivers, one per channel. The idea behind the 18" drivers is exactly what you described: whatever correction I use (DBA, ART or EQ), a good part of the output gets "eaten" by the system. The rear subs in a DBA work against the wave instead of adding level, ART outputs out-of-phase sound and cuts peaks, and a flat or boosted target needs headroom on top of that. So I want plenty of margin to start with.
To be honest, the DBA with Acourate is tempting on paper, but the learning curve is very steep: everything is manual (time alignment, rear delay, polarity, iterations). That's why the simplicity of the Tide16 + ART is so attractive to me.
A few more questions, if you don't mind:
1. With the +9 dB LF target, how close do your subs get to their limits at high volume? Did you feel ART cost you noticeably more output than BC?
2. Have you tried the infra bass bypass, or read reports from people using it with BEQ content?
3. For your DIY build, why did you choose dual opposed 15" over a single 18"? Excursion, distortion, cancellation of mechanical vibration?
Thanks again for taking the time!
That is what the ART docs say, but I would suggest reading about experiences reported on ASR and AV Forums, as I get the impression that many have experienced something described as a severe bump or dip. I got a deep dip around 20Hz. I listened to it with some infrasonic movie content and did not like how it sounded. I'm not currently interested in infrasonic so I disabled the bypass and moved on. Your room might not have the problem with the infra bypass, but if infra is important to you I would highly encourage you to test it before committing to ART. Maybe a used Denon X3800H that you then resell? Maybe the free 14day trial of Dirac ART on a spare Windows or macOS computer you have.
Agreed on the simplicity aspect. More time spent enjoying the music and movies!
I have no experience with DBAs, I also don't know how well a DBA-like setup with the subs on the floor (vs at half-height to excite the height room mode) would work, but I do worry that you will have a problem with infrasonic and ART. Again, maybe a thread on the AVS DIY forum. I'm pretty sure you will get some helpful folks who actually understand and have built DBAs and SBAs to respond.
First, I don't think you can reliably apply any of my experience to your room and your subs.
Second, some context: I'm focused on making big leaps (multi-subs, then absorption and ART, then larger/better subs and mains) until I stop hearing significant differences. No, I'm not verifying changes/improvement with measurements. I'm no expert, but I feel like my decisions are largely rooted in well established small room acoustic science and accurate speaker measurements, and each upgrade so far has made a large enough improvement, that I honestly just don't feel the need to quantify it with measurements (yet).
But if it helps... The Starke SW15 are objectively good subs (based on James Larson's measurements) for $600 each, but they are not in the same class as the drivers you are planning to use. I deployed the SW15 subs as a relatively inexpensive way to verify that four subs + ART would give me good results in my room before I put in the effort to build subs. At volumes I actually listen at, I don't think I'm hearing obvious distortion or compression or the amp limiters kicking in, but I also don't know. I'm not sure I know what to listen for, and I have not measured. I can't say if ART costs me noticeably more output than BC. BC sounded great, but then I heard ART and never bothered to check or care if I was losing output. A few things (the target curve, the volumes) changed quickly in that switch from BC to ART, so I can't isolate any lost output.
I have aesthetic and space requirements that simple don't allow any commercial subs that I can find at a price I'm willing to pay. If I didn't have those aesthetic and space constraints, then I'd already have four of these or these. If I didn't have that price constraint, then I'd already have four of something from Harbottle.
Instead, I'm spending the time and money to build something that fits and looks good. The biggest cost of my DIY subs is my time, so I'm mostly just trying to achieve as much displacement as possible within the constraints I have, to avoid the time of building new/more subs before too long. Because the only room up front for subs is under the speakers = dual opposed to prevent speaker vibration. Limited space = sealed, 15" drivers. Drivers that have good excursion, work well in small volumes, and don't cost a fortune = Dayton SS15-22. These drivers have a stated linear excursion ±22 mm. I doubt I will actually ever use all that, but a great way to help ensure low distortion is to run a driver well under it's limits.
Your constraints seem very different than mine. Certainly BMS 18N862 drivers in 0.55 cubic meter boxes is very different than.
Happy to contribute!
Thanks again, A_RON. Very generous answers, and your point about the infra bypass may have saved me from a costly mistake.
The project is still in the planning stage and the build won't happen right away, but this discussion has helped me set the plan for when it does:
  1. Place the 4 subs first, since the layout works for both ART and a DBA.
  2. Before committing, test both approaches in the actual room: the Dirac ART trial on a PC and the DBA with Acourate, checking the infra bypass carefully with BEQ content.
  3. In the meantime, ask on the AVS DIY subforum about a floor-level DBA vs ART, as you suggested.
It will take a while, but when I get there I'll try to report back with measurements comparing the two in the same room.
Good luck with your DIY subs, I'd love to hear how they turn out!
Sounds like a great plan! Yes, please do report back, it's always interesting to see what others are building. And yes, there will likely be a post on AVS DIY about my subs once they are under way.
