This is my first foray into FIR, so I’m just adding a datapoint from the 2.2 stereo music branch of my larger 5.2.2 system.
For stereo sources only, meaning Plexamp, Spotify Connect, and CD/HDCD, the chain is Raspberry Pi music source to a PipeWire/Pulse virtual sink, then CamillaDSP running the DecayCore FIR filter, then into the miniDSP Flex HTx USB input, then through my existing Flex HTx calibration before output to the amps, mains, and subs.
The Flex HTx remains the main system-integration layer. It handles the crossover, delays, sub EQ, APFs, output routing, and the 2.2 matrix. My stereo bass matrix is not simple summed mono. The left channel feeds the left sub at full level and the right sub at a lower level, while the right channel feeds the right sub at full level and the left sub at a lower level. The idea is to give each main stronger support from its adjacent sub while still using some crossfeed for modal coverage and seat consistency.
Because the Flex HTx already handles bass management and sub/main integration, I did not use DecayCore to redesign the bass or crossover. I used it only as a conservative upstream FIR polish layer.
Measurement was done with a UMIK-2 and its 90-degree calibration file loaded. DecayCore settings were v1.1.7, Basic mode, 48 kHz, 16384 taps, Minimum Phase, Harman6, with correction limited to 250 to 8000 Hz. TDC, HPF, and bass integration were left off. DecayCore report estimated Schroeder around 255–257 Hz.
My reasoning was that the measurement includes the full in-room 2.2 system, including mains, subs, Flex calibration, and room behavior. I did not want aggressive time-domain correction fighting the existing HTx calibration. Minimum phase and a limited correction range seemed like the safest first pass.
The result was roughly 81 acoustic score, about 90 percent target match, and about 93 percent confidence. Subjectively, it sounds a little cleaner. As a conservative post-DSP layer on top of an already-integrated manual Flex HTx calibration, it seems to work well.
Attached are the L/R result plots and recorded/IR/magnitude previews.
