DecayCore 1.1.4 is out
a few things worth mentioning.
Bass integration, rebuilt (v2) — The sub/main handoff now chases
phase through the crossover instead of obsessing over a perfectly flat magnitude curve. Turns out the bass sounding tight and connected matters more than a graph looking pretty. Who knew. The result is a cleaner transition and better transients where the sub meets the mains.
Higher export rates on multi-rate — Added 352.8 kHz and 384 kHz. Do you need them? Probably not. Can you have them now? Yes. Match your playback chain exactly, no resampling required.
DSP / filtering refinements — More robust −6 dB calculation (more dependable crossover and bandwidth numbers), plus reworked stereo policy and filter generation with new guard thresholds and smoothing. Translation: cleaner filters, fewer edge cases reaching for the pitchforks.
As always — feedback and measurements welcome. If something looks off in your setup, post it here and I'll dig in.
