VilhoValittu
- Joined
- Jan 6, 2026
- Messages
- 111
- Likes
- 213
- Thread Starter
- #41
DecayCore uses frequency-dependent smoothing that varies continuously based on frequency and acoustic confidence:As I understand it, DecayCore don't have resolution settings for the FIR filter - 1/24 octave for low frequencies, 1/3 octave for highs, etc.? What is your default filter resolution?
- Bass (below ~120 Hz): ~1/96 octave — very fine, because modal behavior in the bass warrants precision
- Midrange transition (~120–350 Hz): blends progressively wider
- Treble (above ~350 Hz): ~1/3 octave — broader, because trying to correct the high end at 1/96 oct resolution mostly just ends up chasing measurement noise
So the effective behavior ends up being similar to what you described — fine resolution at lows, broader at highs — but it's driven automatically by the pipeline rather than set manually.
