VilhoValittu
- Joined
- Jan 6, 2026
- Messages
- 107
- Likes
- 202
- Thread Starter
- #21
That's actually a very good point.I am personally working on, planning for a multi-sub system that will be "somewhat portable", sometimes used outdoors.
So room correction needs to be kept a separate "layer" from the crossovers "speaker building" / bass management side.
Even maybe doing the timing / spatial tuning, smoothing for a wider LP area separately from magnitude, otherwise the driver layout, relative distance differences must be precisely maintained setting up every time.
but if truly automated, that is A Good Thing
then maybe doing it all together is OK if the workflow is sped up.
What you're describing is one of the reasons subwoofer integration is proving much harder than ordinary room correction.
For a fixed listening position, it's often possible to optimize crossover frequency, delays, gains and phase relationships quite aggressively. But as soon as you start optimizing for a wider listening area, portable systems, or systems that are frequently moved, some of those assumptions break down.
I think there is a strong argument for treating speaker integration / bass management and room correction as separate layers. The challenge is that they are also strongly coupled. A crossover decision affects the room response, and the room response affects what appears to be the "best" crossover decision.
My current goal is not to force everything into a single giant optimization, but rather to find a workflow where the integration layer and the room-correction layer can cooperate without the user having to manually iterate between them.
Whether that eventually ends up being one optimization stage or multiple stages is still an open question. The more measurement data I collect from real systems, the clearer that answer becomes.
