DecayCore 1.4.3 is out.
The first thing in this release is for anyone who hits a problem, Mac users most of all.
On a Mac, Start_Decay.command hides the terminal output, so when something went wrong I had little to go on. The new log file fixes that:
1. In About DecayCore, tick "Save a log file".
2. Repeat the problem.
3. Click "Email the log". Your email app opens a draft to me with the end of the log. An email link can't attach files, so attach the newest file from Documents/DecayCore/logs. The draft names it.
For audio device problems, also run
./Start_Decay.command --audio-diagnostics in a terminal. It prints the audio backends and devices without opening a stream.
./Start_Decay.command --lan now works too and prints the addresses in the terminal, so you can open DecayCore from another computer on your network.
Also new:
- Placement hints. Results lists up to three deep, narrow bass nulls that no filter can fill, each with the distance to a reflecting surface that can cause it. Moving the speaker, subwoofer or seat does more than any filter.
- Equalizer APO and PipeWire files. Tick the option in Output settings and the export gets a ready-made config for each, next to the CamillaDSP files.
- Profiles. Save your settings under a name on the Setup page and load them again, for example one for music and one for movies.
- Fixes. Asymmetric and Linear Phase filters with crossovers set under XO no longer fail the final safety check, and Automatic mode now shortens many more filters. Earlier Automatic results are rebuilt.
Download v1.4.3
