GabrielPhoto
- Joined
- Jul 14, 2020
- Messages
- 371
- Likes
- 212
Ok so it comes down to those 3 receivers....
This is my current line of thinking for each of them.
Denon 3800h:
Possibility of Dirac....but is it ANY better than Audyssey that I am used to?
Selectable pre-amp mode so I can use my 7 channel amp (1.6v) and power Atmos with the AVR. That way I should be getting about 90dB SINAD
Then there is the 4 sub output also.
Tactile transducer option would be nice in the future.
Price wise I can get it cheaper than the other 2 (just need to wait until first week of December to receive it though)
Denon 4700h:
In FULL Preamp Mode I get the highest SINAD (does it even matter though?) at 1.6v
It is the only one that got a recommendation from AMIR.
Used price is about the same as the new 3800h for me.
Con is that to go full preamp, I will need to buy an extra 4 channel amp. Or deal with the 80dB SINAD at 1.6v in non preamp mode.
Onkyo RZ50:
Dirac already there...but is it any better? Looks more complicated and flexible but what about actual results??? There will be a learning curve.
SINAD looks to be around 95dB without needing a preamp mode at 1.6v thus I wont have to buy any extra amps like with the 4700h to get into the higher SINAD performance. Odd how this can be cleaner than the 3800h without a preamp mode.
Runs cooler than the other 2.
Cons are one single sub output...no Audyssery (con or pro? lol). The most expensive for me of the 3. Extra learning curve as I am used to Denon and Audyssey.
Extra info, I have a Monolith THX 365c 7x200 AMP.
7.1.4 setup
I have a MiniDSP that I am yet to learn and use buts is there. The 2x4HD
Only one input from my HTPC HDMI connection to my JVC Projector. Oh and one media box for 3D but hardly ever used.
Denon 3800h:
Denon 4700h:
Onkyo RZ50:
7.1.4 setup
