Jazigo
- Joined
- Feb 9, 2025
- Messages
- 238
- Likes
- 213
Day 1
Dear Diary, my Zero:2s are showing their age, so it’s time for new IEMs. This time I want a metal housing. Something that can survive me.
Finding metal IEMs was easy. Too easy. Three new IEMs have been released since I started writing this sentence, all with a “revolutionary” driver, and at least one with an anime girl on the box.
So I did the sensible thing and mansplained it to myself.
Mansplaining Me put on his Audio Science Review hat and explained, very slowly, that only two things matter: frequency response and distortion. And since I’m going to EQ them anyway, frequency response goes out the window. That leaves distortion. Case closed. Mansplaining Me loves a closed case.
Day 2
Dear Diary, finding low distortion is a lot harder than finding metal. There’s a sea of IEM reviews out there, and almost none of them post distortion. Today I read 40 descriptions of “textured bass” and found zero distortion graphs.
Then some kind souls pointed me to a Naver café that has been measuring IEMs for years, distortion included. I put my trusted AI to work scraping their site. It didn’t complain, ask for overtime, or describe anything as “musical.”
I also found out that Cuckoo Studio, right here on ASR, posts IEM measurements with distortion graphs. Bless you, @Cuckoo Studio.
Day 3
Dear Diary, I wanted to give something back, so I shared it all on r/iems. I wrote two lovingly crafted posts with the Naver café data and the Cuckoo Studio data, including 118 IEMs’ worth of distortion graphs I digitized. I expected a parade.
I am now the most unpopular person on Reddit.
Mansplaining Me says downvotes aren’t a measurement, so they don’t count. Easy for him to say. He doesn’t have a Reddit account.
(Evidence for the curious: Exhibit A, Exhibit B)
Day 4
Dear Diary, Reddit may hate me, but the data still loves me. I stared at distortion graphs until my vision had a flat frequency response, and the data has spoken: the Moondrop Aria 2 and the Moondrop Kadenz, two single dynamic driver IEMs. I ordered both. For science. Definitely not because I have a problem.
Day 10
Dear Diary, the Aria 2 arrived, and what an upgrade from the Zero:2! The Zero:2’s nozzle is so short it basically waves at my ear canal from across the room. The Aria 2’s longer nozzle actually goes in. It feels like it was made for my ears. Instant win.
Mansplaining Me pointed out that a better fit is just a better seal, and a better seal is just frequency response. Nobody asked, Mansplaining Me.
Day 12
Dear Diary, the Kadenz arrived, and I need to tell you something you can never repeat on ASR.
It’s better. Not a little better. A mile and a half better. And that’s AFTER PEQing both to the exact same target (AvgPop-DF with a -1 dB tilt). Same target, Diary. Same. Target.
Mansplaining Me didn’t even look up. “It shouldn’t matter,” he said, and went back to sorting DACs by SINAD.
Day 13
Dear Diary, if two IEMs EQ’d to the same target sound different, maybe the measurements behind my EQ are off. So I dug through every squig.link site I could find and compared. The graphs are all over the place, mostly thanks to insertion depth and different tips. So which one is correct? Who measures the measurers?
Luckily, I found a B&K 5128 measurement from Moondrop themselves and crowned it the reference. Earphone Archive (my Naver café heroes from Day 2) matched it almost perfectly. Hangout Audio used different tips but came very close too. Good enough for me: Hangout Audio is my reference, and the Aria 2 should end up close.
Day 15
Dear Diary, it did not end up close.
They still sound different, so I’ve built a proper test rig: Tidal playing into two separate DACs, Aria 2 in one ear, Kadenz in the other. The Kadenz clearly has a wider soundstage and cleaner separation of instruments.
I just wrote “wider soundstage” in my own diary. Mansplaining Me went to his room and slammed the door.
Day 18, 3:47 AM
Dear Diary, several days of frustration now. Two DACs, two volume levels, infinite ways to fool myself. Mansplaining Me still isn’t speaking to me.
Tonight I gave up and simplified: one DAC, one 3.5 mm cable, an Aria 2 earpiece on one side and a Kadenz earpiece on the other. My very own Franken-pair.
And lo and behold... they sound identical.
Okay, almost identical. A few small discrepancies were left, until I figured out that Hangout Audio’s graph is the average of the left and right channels, and the Aria 2 has a fairly big difference between its two sides. So I made an EQ for the left side only.
Now they sound exactly the same.
Mansplaining Me came out of his room for the first time in days, said “Told you,” and went back in.
Day 19
Dear Diary, lessons learned:
Day 2
Day 3
Day 4
Day 10
Day 12
Day 13
Day 15
Day 18, 3:47 AM
Day 19
- Even small differences are audible, and your brain will happily call them “soundstage.”
- Volume matching isn’t optional. It’s dead essential.
- Averaged graphs hide channel imbalance. Check your left and right.
- Sort all that out, and two IEMs EQ’d to the same target really do sound the same.
