I ordered an Archel2 Pro after reading the reviews here and I wanted a small-ish amp to put in the bedroom for ad-hoc listens. There was some initial back and forth that they don't directly ship to my location but in the end I figured I'll take a bet and order through a forwarding service. Fast forward to the day I got it in the mail. I plug in the amp to the provided power supply, headphones, switch on and... drum roll.... nothing. No sound. Just pretty LED lights.
I reached out but after a first reply where I think the folks at Geshelli wanted to see if I hadn't tapped the input selection button enough times to be on the right configuration, the line went dead. One observation I had was that when I turned up the volume knob, when it's near max, I hear some faint crackling music coming through. This applies even after I power off, disconnect from the AC and keep my source running. Anyone has a clue what might be the case? A bad component?
Otherwise it works as advertised - the LED changes color if I tap the power button, I heard a faint click when I hold the input button to toggle gain mode. Should I keep it as a pretty paperweight?
