E1DA PowerDAC v2.1 DAC + HPamp
"portable" but see power caveat below
Full Digital Amplifier (FDA), "digital-to-power" topology, converts the PCM digital input signal straight to Pulse Width Modulation (PWM) waveforms, eliminating line-level DAC stage entirely
no dedicated preamp output, cannot bypass the powerful internal amplification stage to get a clean line-level signal – see E1DA 9038SG3 or 9038D6K instead
7-band parametric EQ (PEQ), filters (LPF, HPF, APF), and a compressor/limiter
The newest PowerDAC for the Head-fi universe is released! It is pretty much the same device as PDv2, however, now PowerDAC can work with unbalanced headphones as well. HPToy iOS/Android app was modified to get the switch for 3 output modes: 1) Balanced - the same as PDv2 balanced 2.5mm TRRS up...
www.linsoul.com
From Google (feedback welcome)
HP amp: Balanced (600mW)
SE RCA (lower power via adapter) vs "Unbalanced Boost" gain (full 600mW with crossfeed)
third-party measurement data for Full Digital Amplifier (FDA) devices like the PowerDAC V2.1 is minimal compared to standard DACs.
Traditional audio analyzers (like an Audio Precision machine) cannot measure its signals cleanly without a physical headphone load or a specialized hardware low-pass filter attached. However, hardware measures include
Output Power: 600mW per channel into a 15-Ohm load at 1% THD
For standard 32-Ohm loads, it reliably pushes around 320mW
Frequency Response: 20Hz–20kHz (+/- 0.2dB)
THD+N (Total Harmonic Distortion + Noise): It scales directly with the digital signal volume level:
* 0dBFS (Max Volume): < 0.05%
* -3dBFS: < 0.03%
* -10dBFS: < 0.01%
Signal-to-Noise Ratio (SNR): ~ -108dB(A)
Output Impedance: relatively high at 1.5Ω, better for planar or high-impedance dynamic drivers, less so for lower impedance sensitive IEMs, can result in an audible noise floor / hiss
draws high current over the USB rail, so requires a quality USB power supply
Thanks! I think I almost have all the info I need before choosing the dac/amp to use with my iPhone! The last thing I want to figure out is power consumption. Do you know how I could compare the power consumption between the Linsoul E1DA 9038S Susumu 3000 Gen3 (4 vrms), Luxury & Precision W2 (4...
www.audiosciencereview.com
www.head-fi.org
