Well there you have it. All hearing happens in your head. The science on this does not cater for reality and no microphone or measuring device can accurately capture and deal with soundstage or room reflections the way our brains do
Indeed, but what the science can precisely tell you is whether it is
possible for the electronics to influence the sound which with normally engineered electronics is no.
With eccentrically designed electronics maybe the sound is altered but we can measure that to a higher degree of accuracy than ears, and it is because the electronics isn't working properly.
What we can't measure is the placebo effect - which is very powerful, particularly people susceptible to believing a reassuringly expensive capacitor, for example, will improve the sound. I wonder why it is never a delightfully inexpensive component that works best to the placebo susceptible...
We can't accurately enough measure the sound at the listening position to consistently predict the change in stereo image created either by moving soft or hard furniture.
We can measure the substantial change in sound at the listening position, either by moving the speakers in the room or the chair you sit in, but not, afaik, predict from those measurements the precise influence on the sound stage that causes.
