If your eguipment has 50/60 Hz power transformers, the transformers will go up in smoke when powered by DC. If you have switch mode supplies instead, they may work well with DC.My hypothesis (I don't know if you know better or if it has already been proven) is the sound quality better with DC power than with AC power? Because DC does not need ground as much as AC. I want to run the system with only DC power.
I want to run my system completely DC power is it wrong?
But non-standardized DC voltages present another challenge! Your laptop likely requires ~19 volts, but a Class D power amplifier may work best at 48 volts, and so on.With laptop battery there is no smoke
That's true, a laptop battery can't power an amplifier, my system is, guitar -} a battery powered EQ pedal-} one interface-} one 40 watt amp or headphones-)one laptop simpleBut non-standardized DC voltages present another challenge! Your laptop likely requires ~19 volts, but a Class D power amplifier may work best at 48 volts, and so on.
On the extremely off chance this is serious, all components convert from AC wall power to DC internally (or through an external power brick), so technically all of your system is already run by "DC power".My hypothesis (I don't know if you know better or if it has already been proven) is the sound quality better with DC power than with AC power? Because DC does not need ground as much as AC. I want to run the system with only DC power.
You already are, so, no. But it is unlikely to benefit the sound and be challenging (and costly) to implement.I want to run my system completely DC power is it wrong?
Your articles are very interesting but overly technical. I wish there was a more simplified version for us mere mortals. I ordered a signal line isolator (but customer service said not to use it for long periods of time during the day).On the extremely off chance this is serious, all components convert from AC wall power to DC internally (or through an external power brick), so technically all of your system is already run by "DC power".
Current conduction is a loop, so there must always be a return, ground or otherwise, whether the incoming source is AC or DC. Ground loops can occur whatever the power source; do a search and you'll see all sorts of ground loop problems in cars which use "DC power". They may be less obvious using battery (DC) power since there won't be a 50/60 Hz signal from the power line, but the loop could still be there given different components powered by the same DC supply. I have an article about ground loops (see link in my sig to a list) with some pictures showing multiple loops that exist no matter the power source.
There are a lot of drawbacks to using batteries to power systems. Batteries need recharging and have limited lifetime, have limited energy density, generally have higher impedance (are a poorer power source) compared to AC (wall) powered DC supplies, and there are concerns with leaking, exploding, and disposal.
A laptop running on its battery breaks the safety ground connection thus no loop. There are plenty of other means for isolating the ground in that situation, using either power line or signal line isolators, but if that is the only issue you can either run the laptop on battery when you use it or purchase a power line isolator for the power brick (e.g. https://www.amazon.com/Ebtech-Hum-Ground-Voltage-Filter/dp/B0002E4YI8). Or figure out the root cause of the loop and fix it.
The supply for that charger is a switchmode type, as almost all of them are. So no smoke is what you should get when DC Is used to power them.
With laptop battery I didn't get any smoke
Eliminating ground loops can be simple, but often is frustrating (especially if you want to be safe). Studios use balanced / differential working to minimise the issue.Your articles are very interesting but overly technical. I wish there was a more simplified version for us mere mortals. I ordered a signal line isolator (but customer service said not to use it for long periods of time during the day).
Thank you very muchEliminating ground loops can be simple, but often is frustrating (especially if you want to be safe). Studios use balanced / differential working to minimise the issue.
If you find the article by @DonH56 (which is not too challenging - just take your time and go over it a few times), you may find this article helpful: https://www.edn.com/the-g-word-how-to-get-your-audio-off-the-ground/
What about USB isolators?On the extremely off chance this is serious, all components convert from AC wall power to DC internally (or through an external power brick), so technically all of your system is already run by "DC power".
What equipment and devices do studios use for such problems?Eliminating ground loops can be simple, but often is frustrating (especially if you want to be safe). Studios use balanced / differential working to minimise the issue.
Balanced connections. Virtually all pro equipment used in studios and live has balanced inputs & outputs. Virtually all home equipment has unbalanced connections (RCA or 3.5mm).What equipment and devices do studios use for such problems?
When I was designing PLLs and clock generator circuits I would use battery power, working inside a screen room (aka Faraday cage) to get the absolute minimum noise possible.
But using a DC battery to power a stereo system for dubious audio benefits falls into 'tin foil hat' territory, IMHO.
