- Joined
- Feb 27, 2020
- Messages
- 127
- Likes
- 154
Ever needed an amplifier for a passive sub? Want to run your car sub in your home? Want to build a sub yourself?
You came to the right place!
Presented here for your consideration:
The Dayton SA1000 Subwoofer Controller!
$300 shipped Cronus including PayPal G&S
1kW into 4 Ohm
12v trigger
Full range passive unbalanced input
...or single sub input (rca)
High Pass output
Remote Switch
Bass Boost switch
Sub Sonic Filter switch
120/60 or 230/50 V Power.
Rack mountable
30 lbs, W17”, H5”, D14”
Built like a tank and runs silently
Like new, all original packaging
I’m going from a 2 sub setup to one. I’m driving a Sundown SA12 2ohm which delivers way more energy than an average house can take.
From the manufacturer:
Highlights
The Dayton Audio SA1000 is a freestanding, high-power subwoofer amplifier designed for the DIYer, installer, and systems integrator. This unique monaural audio device delivers the raw power of a pro-sound amp, but with the features and flexibility of a dedicated subwoofer amplifier. It can be configured for stacking with other audio components, and includes removable ears for mounting in standard audio racks (2RU). The SA1000's patented tracking down-converter power supply ensures headroom for instantaneous power needs and the amp stays cool, thanks to its high-efficiency design.
A Class-AB amplifier configuration provides the SA1000 with clean and controlled output. From an application standpoint, the SA1000's low frequency parametric EQ enables you to boost or cut to custom-tailor the sound to suit the listening environment. Sophisticated soft clip circuitry provides cleaner transient peaks while protecting your driver from over-excursion. The amp's switchable subsonic filter removes subsonic information from the signal, which tightens the low end response of some subwoofer systems. On-board bass boost filters enhance LF performance while leaving the parametric EQ function available to address room modes, like cutting an excessively loud room resonance. The high-pass outputs provide a user the option to feed the signal back into their other audio components or a distributed audio system.
Manual, automatic on/off or triggered 12V input modes allow easy integration into automated systems. The stealthy pop-out knobs on the front panel make adjustments easy, while minimizing the risk of accidental disturbance. The SA1000's subdued brushed black aluminum faceplate allows the amp to blend cosmetically with any type of audio gear. Accommodates RCA line-level inputs, includes insulated binding posts for the speaker outputs, and accepts a 12V trigger via a 3.5 mm mini-jack.
Specifications: • Rated power output (0.92% THD): 497 watts into 8 ohms, 950 watts into 4 ohms • Signal to noise ratio: 98 dB A-weighted • Efficiency: 86% • Input impedance: 12K ohms • Input sensitivity: 775 mV • Subsonic filter: -3 dB @ 18 Hz, Q=0.8 • Bass boost: +3 dB @ 25 Hz, Q=1.4 • High pass output: -3 dB @ 80 Hz, 12 dB/octave • Low pass adjustment: 30-200 Hz with 24dB per octave slope • Phase adjustment: 0°–180° • Parametric EQ frequency: 18–80 Hz • Bandwidth: 0.1–1.0 Q • Level: -14.5 dB to +6 dB • Dimensions: 17-1/2" W x 4" H x 13" D (tabletop configuration) • Power requirements: 120/230 VAC, 60/50 Hz • Stand-by power rating: 120V 24W; 230V 18.4W • Weight: 28 lbs. • Power rating based on one-third power duty cycle.
This amplifier is based on the Bob Carver Sunfire True Signature Subwoofer amplifier.
I had 2 of those and they were incredible.
I have 2 of these SA 1000 Subwoofer controllers, I will always have one. These amplifiers are indispensable if you build your own subs.
I’m upgrading my driver from Sundown SA12
25lbs, 2” Xmax...
to Stereo Integrity’s HST 12 MkII (Made in North Carolina by Sundown Audio)
80lbs. 4”Xmax
Both of these drivers are for sale as well. I hope to keep the HST.
https://sundownaudio.com/index.php/subwoofers/sa-series
https://www.parts-express.com/dayto...ier-rack-mountable--300-811#lblProductDetails
Warranty and Repair by Dayton Audio
https://stereointegrity.com/product/sql-12/
1kW into 4 Ohm
12v trigger
High Pass output
Remote Switch
Bass Boost switch
Rack mountable
Highlights
- Patented tracking down-converter power supply for high efficiency
- Class-AB output stage for clean, controlled amplification
- Low frequency parametric EQ allows you to boost or cut to custom-tailor the sound
- Sophisticated soft clip circuitry improves headroom and protects woofers
- Manual, auto, or triggered on/off for integration into any automated system
- Switchable subsonic and bass boost filters
- High pass output for looping signal back into distributed audio systems
25lbs, 2” Xmax...
80lbs. 4”Xmax
