Dayton Audio SPA250DSP subwoofer amp
Dave TR3A
near Toronto, Canada
Not quite 3 months ago, Amir posted a review of the Dayton Audio SPA300-D subwoofer amp. There was considerable interest in the post so that the thread ran to 70 posts.
I have taken some measurements of my Dayton Audio SPA250DSP subwoofer (plate) amp and I thought I would post my findings in case others might be interested. Although more recent that the SPA300-D, the SPA250DSP is getting long in the tooth, having been introduced in 2017.
The SPA250DSP combines a 250W class D amplifier with a DSP.
  • Power is rated at 250W into 4 ohms, THD <0.1%
  • Input sensitivity (RCA) is 320 mV - 1.4 V (for XLR it is 630 mV - 2.7 V)
  • RCA and XLR connections
  • Two input modes: NORMAL (no attenuation) and HI LEVEL (-6 dB attenuation)
  • Frequency range of 30 Hz to 125 Hz
This link provides more information about the SPA250DSP.
I doubted the specs, particularly those for input sensitivity. When I provided the the SPA250DSP a 100 Hz input at 1.4VRMS (via RCA) when the amp was configured for “Normal” input (i.e., no attenuation) and the VOLUME set to 0 dB (no attenuation), the amp's LIMIT LED always lit and the amp clamped the output signal amplitude.
I wanted to determine what input signal amplitude would result in distortion (at 0 dB attenuation) and what power the amp would actually produce at different input signal amplitudes.
Testing
The SPA250DSP input switch was set to NORMAL (i.e., no attenuation) and VOLUME set to 0 dB. An arbitrary waveform generator was used to send an input signal at different frequencies (30 Hz, 60 Hz, 80 Hz, 100 Hz, and 125 Hz) and amplitudes to an RCA input. The amplifier outputs were connected to a 4.2Ω/400W dummy load and an oscilloscope displayed the output signal so that I could watch for clipping/distortion.
The SPA250DSP’s LIMIT indicator was also observed. The LIMIT indicator turns red when the audio signal exceeds 0 dB. When lit, the amplifier automatically attenuates the volume.
Noise
With no input signal applied, this output was captured on the oscilloscope:
It's a ~280 kHz sine wave that I attributed to the amp's power supply. I wasn't surprised to find noise from the PS on the output, but I expected the switching frequency would have been higher and that the amplitude of the noise signal would be lower (it was about 3.8 Vpp/1.3 Vrms).
The fuzziness is always present but doesn't dominate the output at higher amplitude input signals.
Input sensitivity
My tests did not support the claimed input sensitivity. Although I was not able to measure THD+N at different input amplitudes, the amount of distortion (fuzziness) in the output traces made me suspect it was well above the claimed 0.1%. Also,
  • At input signal amplitudes >600 mVrms the signal would visibly distort.
  • Above 600 mVrms, the SPA250DSP's LIMIT indicator would also light and the output would be clamped to about 82.4 Vpp (~200 Watts).
  • Below 100 mVrms, the SPA250DSP could not reproduce the frequency of the input signal reliably; the frequency would deviate by around 50%
I concluded that the useful range for input signal amplitude was between 100 mVrms and 600 mVrms (when the input selector was set to NORMAL). If the input selector was set to HI LEVEL (i.e., -6 dB attenuation) the usable input signal amplitude was up to 1.2 Vrms.
I did not test using the XLR connections.
Power
I wanted to understand the effect that setting the input selector to either NORMAL or HI LEVEL would have on the SPA250DSP's output power.
This graph shows the power produced (into 4 ohms) from input signals with different frequencies (30 Hz, 60 Hz, 80 Hz, 100 Hz, and 125 Hz) and amplitudes (100 mVrms to 600 mVrms).
The graph shows that the SPA250DSP delivers the 250W that Dayton Audio specifies.
This chart shows details the power output by frequency and input signal amplitude:
Gain
The SPA250DSP's gain is about 45 dB when the input selector is set to NORMAL and about 39 dB when it is set to HI LEVEL.
Although the SPA250DSP is much noisier than I would like, it delivers on its promised power. Although it has DSP capabilities, I am not using them.
While I'm satisfied with my SPA250DSPs (I have two of them), if I knew then what I know now I would have bought something less noisy.
I use the SPA250DSP in my Bill Fitzmaurice-designed (but home built) THTLP folded horn subwoofers. Each THTLP is equipped with a 12" Dayton Audio RSS315HF4 driver and a Dayton Audio SPA250 DSP plate amp.
I was curious to see what SPL I could get from the subwoofer.
I connected an arbitrary waveform generator to one THTLP subwoofer and used it to send a signal at different frequencies (30 Hz, 60 Hz, 80 Hz, 100 Hz, and 125 Hz) and amplitudes (from 100 mVrms to 600 mVrms) to the subwoofer. The SPA250DSP plate amp's VOLUME was set to 0 dB and its input selector was set to NORMAL. I set a UMIK-1 microphone in a stand at 1m from the subwoofer and measured the SPL using the SPL meter in REW. I used C weighting for the SPL measurements.
With an input of just 100 mVrms, the SPL was > 100 dB. At 600 mVrms, the SPL was between 116 and 123 dB, depending on the signal frequency. The SPL was somewhat frequency dependent: highest around 80 Hz and the dropping as the frequency increased or decreased. The lowest SPL was measured at the extremes: 30 Hz and 125 Hz.
Since I have two THTLP subwoofers, the SPL that is produced is about 3 dB higher that that produced by a single sub. At the volumes I listen at (typically near or below 90 dB), I doubt I pull more than 50W from the SPA250DSP amps.
Testing
Noise
Input sensitivity
Power
Gain
I like your amp stand. :)
On topic: Assuming the noise is intrinsic and not symptomatic of an old(er) amplifier* that is showing its age -- how the heck could someone look at the performance of a beta version of this amplifier and say: "yeah, that looks fine."
I can build an amplifier power supply (albeit a linear one) that doesn't do that, with parts out of the junk box -- and I barely know what I am doing.
_____________
* I am assuming your test amp has some hours of service on it. I bought the one here when they first came out - although, admittedly, I haven't really used it all that much.
_____________
My SPA250DSP amps are about 4 years old. I can't discern any difference in how they perform now versus how they performed when brand new.
I agree. I was surprised that Dayton Audio didn't filter away or significantly attenuate the noise from the PS. Although I'm unable to measure THD+N, it beggars belief that they are achieving <0.1% THD+N with all that noise.
Although I initially used the SPA250DSP's DSP capabilities, I moved away from that in favour of a MiniDSP 2x4HD and then a MiniDSP Flex Eight. I have pretty much disabled (or set to neutral) all of its DSP functions.
Dayton must have simply relied on the passive filtering that the large, paired woofer would provide (something our large, non-inductive resistors—used for our tests—don't achieve)... I suppose we could say they’re right, couldn't we?
Needless to say, I don't know... but I would wonder whether they're that clever. ;)
It would still be something of a crapshoot, since the best they could do design around some average (or, perhaps more to the point, most likely) woofer parameters... no?
Plus, I cannot help but think that the guts of these amps were some Asian OEM's off-the-shelf board(s).
Do note the weasel-wording I have carefully inserted above in terms of my suppositions. :)
Filtering at high power is no easy task... and if it actually ends up being implemented under real-world conditions—well, what’s the point?
