Dayton Audio Sensitivity measurement
audio_04
Hi everyone,
Does anyone know how Dayton Audio determines or measures the sensitivity specification of their drivers?
According to the attached datasheet, I would have expected this tweeter to have a sensitivity of around 94 dB SPL, based on the relatively flat part of the frequency response between roughly 2 kHz and 5 kHz. However, the datasheet states a sensitivity of 91 dB SPL.
Do they measure sensitivity at 1 kHz? Or do they take the entire usable frequency range (for example, from about 2.5 kHz to 20 kHz) and calculate some kind of average value?
I need to adjust the tweeter level to match the sensitivity of a woofer, so I'd like to know which SPL value I should use as a reference for this adjustment.
You should really compensate for the waveguide: it boosts the low end significantly. Once you bring that down, the 91 dB aren’t so strange. Best to measure, not guess.
The frequency response graph does not specify the drive level, so is useless for judging sensitivity.
No, the datasheet states an efficiency of 91dB @1W/1m. This is important to differentiate.
