Dayton Audio MKSX4 Passive Subwoofer Review
Rate this passive subwoofer:
    Votes: 51 46.4%
    Votes: 46 41.8%
    Votes: 11 10.0%
    Votes: 2 1.8%
I would not say so. It is a small music subwoofer, for those 2.1 desktop amplifiers. From this box no one will expect earth shaking low bass. It can sound good with music when not over powered and filtered properly. Maybe 40 Hz 12 dB High pass and 120 Hz 24 dB Low pass combined with 4“ to 5“ mains. It does not look like one note bass at all.
The natural pairing satellites to this device are the Dayton Audio SAT3B released with a 130Hz - 20kHz frequency response.
Is there merit in testing such a subwoofer through a real life filtering with white or pink noise ?
I'm looking at the in-room response:
Amir's measurements pretty much always show a bass shelf down. Don't assume that's what your response will be, these are some what anomalous.
Is there a common definition of one note bass? I always thought of it as a noticeable bump in frequency response. Or bass is driven into distortion by too much power or a weak amp, becoming smeared and farty. -Not early drop off, but it wouldn't be the first time I'd misunderstood "technical" terms.
Cheers!
Despite the apparent lack of distortion in the bass, it seems to me like this would only be useful for filling in the mid- and upper-bass (100Hz to 400Hz) if the other speakers were seriously deficient in that range. Once you're below 100Hz this thing's output drops like a rock. Which isn't terribly surprising for a box with a few 4" drivers.
Imho they went for Spl and cramped too many drivers in an enclosure too compact. The would get a better response using 2 5,25 inch drivers or one 6.5 like Ik multimedia did.
I mean they have the drivers. They probably want to market it as "opposing symmetrically placed woofers reducing resonances of enclosure" kind of thing but i have not seen the inside tbh. Nah... This here is he exact meaning of the sentence "nothing to write home about speaker"
It is NOT a true sub, and that is fine.
MBM Coupler for bass **reinforcement** like Wiim Sub Pro.
Please post other comparable high SQ units AS MBM in such a slim WAF form factor.
That is the USP pitch, not technical implementation details!
@amirm is it possible for you to do a re-review of this sub? I think it would be important to take into account how this sub will have a crossover that probably eliminates everything above 100-120Hz so the "one note" aspect at 400Hz is rendered moot.
