You had me agreeing with you until you mentioned 40-80Hz....
Again, I think it's all a matter of expectation. Yes, you can get decent bass out of 4 4" drivers, two 5-6" drivers or an 8.
And, if someone goes into this thinking I can get some decent added low end, 50-100 with the Dayton 4x4 sub, especially with cabin gain, it's OK.
But think of the alternative. For the same money and some diy effort you can buy a different Dayton sub, say an
Ultimax by Dayton. You put this in a 11" sealed square box. If you can make an 11" box work in your application, you get an 8" sub with a well designed motor a 18mm of Xmax.
I doubt the 4" drivers have more than 4mm of Xmax. I could be wrong, since I haven't looked at the specs for this Dayton 4". But I have looked at specs for other 4" subwoofer drivers. (Yes, that's a thing...
wavecor 4" sub) There's a TangBand 3.5" minisub driver with 5mm. Oooohhh?
Yes, 4 of the Dayton 4" drivers have the Sd of an 8" driver. But, the Dayton Ultimax 8" sub has 18mm of Xmax. a twofold doubling. So the actual max SPL of the Ultimax 8" driver will be ~6dB louder. Which, because of the compression of the Fletcher Munson curves, represents a doubling of audible loudness in these bass frequencies.
So an 11" cube with the Ultimax would put out 6dB more, and give you legit bass in the 30-50 Hz range and some bass even below 30 because a sealed box rolls off at 12dB instead of 24dB/oct. Since you would make it sealed, you also don't have all that IM distortion from unloading of the woofer as the acoustic impedance drops like a rock below port tuning. And, because it's sealed, you get more flexibility since you can generate multiple eq curves corresponding to your output capability. That is, if you want high output, you can tune the F3 to 40-50Hz. If you aren't pushing the SPL's, why not tune the f3 to 30 and a q of 0.5. That kind of eq won't work in a ported sub.
So yeah, this 4x4 slim profile Dayton sub is "ok." The Bose is "ok." I grew up on these kinds of boxes. And if you need it for the form factor, go for it.
But if you can get by with an 11" square size, you'll get a markedly better product for about the same price. With a little DIY work.
Note I'm not trying to promote Dayton/PE. But, I'm not trying to discourage their use. They have some very nice drivers at reasonable prices. I mean, the 8" ultimax is $100.
