Dayton Audio MKSX4 Passive Subwoofer Review
Rate this passive subwoofer:
    Votes: 52 46.8%
    Votes: 46 41.4%
    Votes: 11 9.9%
    Votes: 2 1.8%
This is a review and detailed measurements of the Dayton Audio MKSX4 passive, quad 4 inch driver "subwoofer." It was kindly sent by a member and costs US $145.
Behind that grill there are four drivers arranged on each axis, pointing toward each other. There are then vents/port under the subwoofer. You can place the speaker as I did or its side.
The box is lighter than any subwoofer (24 pounds shipping) and shallower as well (5.9 inches). The main application likely is in a mobile/car situation but of course nothing stops it from home usage.
There is a set of speaker binding posts underneath the box as situated in my picture. They are angled as to reduce their height.
Dayton Audio MKSX4 Subwoofer Measurement
Even though this is called a "subwoofer," it really doesn't go to subwoofer frequencies so I measured it like any other speaker on Klippel NFS. I did reduce the number of scans to half as much as we don't care about treble frequencies. Computed frequency response therefore, lost accuracy in that region somewhat:
Dayton Audio MKSX4 Four 4 Driver Low Profile Passive Subwoofer frequency response measurement.png
As somewhat predicted, speaker is really tuned to output a lot around 400 Hz -- much higher than we would want. There is reasonable output below that frequency but you lose 20+ dB of output.
There is strong resonance near 3 kHz so best to not play it full range.
Impedance is mercifully not too low:
Dayton Audio MKSX4 Four 4 Driver Low Profile Passive Subwoofer impedance and phase response me...png
Distortion is kept very low at 86 dBSPL and still very reasonable at 96:
Dayton Audio MKSX4 Four 4 Driver Low Profile Passive Subwoofer relative THD distortion respons...png
Dayton Audio MKSX4 Four 4 Driver Low Profile Passive Subwoofer percentage THD distortion respo...png
I also tested at 101 dBSPL (not shown) and audibly the unit still performed well during sweep.
There are severe diffractions at higher frequencies which would be another reason to not drive it there:
Dayton Audio MKSX4 Four 4 Driver Low Profile Passive Subwoofer Horizontal Directivity response...png
Dayton Audio MKSX4 Four 4 Driver Low Profile Passive Subwoofer Vertical Directivity response m...png
And like any speaker, it starts to beam as wavelength gets smaller:
Dayton Audio MKSX4 Four 4 Driver Low Profile Passive Subwoofer Horizontal beamwidth response m...png
So don't think it is an omni-directional subwoofer if you get let it play above 200 Hz. You need to point it at the listener.
I am not exporting the spin data since this is not an ordinary speaker.
When I was working on my van's audio system, I was tempted to try a passive subwoofer. Was thinking of 3-D printing something and use multiple 4 inch drivers. So I was pleasantly surprised when a member offered this box at such incredibly low price. Seeing the high resonant frequency is disappointing though. Here is the measurement of my JBL SL2:
We still have a one-note bass but it is in really sub region. That sub is working well at low levels but falls apart if pushed. I am wondering of the MKSX4 does better (post heavy EQ).
Without a reference otherwise, it is hard to pass judgement on the Dayton. I let DIY experts comment on expected performance and applications.
Despite the apparent lack of distortion in the bass, it seems to me like this would only be useful for filling in the mid- and upper-bass (100Hz to 400Hz) if the other speakers were seriously deficient in that range. Once you're below 100Hz this thing's output drops like a rock. Which isn't terribly surprising for a box with a few 4" drivers.
I prefer the passive subs in cars but this doesn’t seem like it would be much use as a subwoofer. I’m currently running a single passive ESX Q168P, which has really nice heavy all-metal build and has nice calling options for doubling up (if needed). Resonant frequency is supposedly around 70db on these and while I couldn’t find any measurements, it does a good job taking the bass demands away from the mid-bass speakers in the door cards. It’s hard to argue with the performance and build quality for <£120 in the UK.
Can't imagine buying a "sub" like this but suppose it has its uses with some satellite speakers? My van has plenty of room for a more reasonably sized sub, tho (use a 12" sealed myself). Didn't see it mentioned, what was used for amp for the test?
I used my Behringer pro amplifier that powers all speakers in Klippel NFS. It produces a few hundred watts without struggle.
Didn't know that. Which model?
In the product listing at their website, Parts Express touts the Dayton Audio MKSX4 passive 'subwoofer' as using the same 4-inch driver as the Dayton Audio MK402 loudspeaker - providing a matched, cohesive sound.
Amir measured a Dayton Audio 'MK402X' loudspeaker in May 2021. It is no longer listed on the website for Parts Express.
Not sure that solid output down to 50hz really qualifies something as a "subwoofer", but OK. You can find plenty of bookshelf speakers that go lower...
I guess the bright spot is the reasonably low distortion even at low frequencies... and the price... but other than that, this shows in one graph why so many people come in looking for "musical" subwoofers that don't have "boomy" bass. That 400hz peak is nightmarish.
Everything will just sound like "HOOOONNNNNNNTTTT" with no mercy.
There might be some good use for it with heavy EQ, but I couldn't tell you what. With enough room gain, you can almost squint and see a real subwoofer after you lowpass the input. But clearly you can't run it full range.
Amir, is your van a Sprinter or Transit?
A shop called diyvan.com run by a nice guy named Hein makes custom wall panels to utilize the sidewall cavities behind the driver's seat for subwoofer installation. He will cut the woofer hole to your spec'd dimensions or they have versions specifically for the Alpine PWE-S8, which is a not-terrible compact powered subwoofer shallow enough to fit in the wall cavity.
I just did a simple sealed MDF sub in a shape that fit an otherwise little-used space in my van, but the diyvan.com products are a decent/simple/cheap alternative if your cabin layout has those wall areas accessible/exposed. The nature of the wall cavities would influence driver choices (free-air design for example).
He also makes custom adapters to fit aftermarket speakers to the front door mounting cavities.
Back in the 80's I worked in a warehouse-ish environment. The mailroom was a cage adjacent to shipping. The guys had a homebrew system of some Triax car speakers mounted in cardboard boxes on a shelf driven by a mobile head unit on a 12v inverter. Listened to a lot of Mets games on that setup. This would have been the sub to add to that. :p
This is almost surely for use with computer speakers or small satellite surround systems that may not go much below 100Hz. Its thin profile allows it to be under a desk, behind an entertainment center, or laid flat under an end table.
  • It is not meant to be listened to in an anechoic chamber, so take the boundary loading into account. While it drops nearly 20dB below 400Hz in 4-pi space, it likely gains 12-18dB. (See image below.)
  • Although it is passive, it is assumed to be used with a low-pass filter which is available on a lot of cheap 2.1 amps which may not include a high-pass for the satellites. Thus, most of that output above 100-150Hz is irrelevant.
So, ignore the output above 100-150Hz and increase the ouput below 100Hz 12-18dB. It is still not a 20Hz subwoofer, but it can probably produce okay output down to 40Hz and a little below in the living room of a small house or apartment. It uses four Dayton Audio TCP115's which sell for $16 each and are known to go pretty low for a 4-inch woofer, but they are a cheap, high distortion driver so it is correct that it is going to be one note bass. But for a PC setup or cheap surround sound system in a small room it does what is needed.
(EDIT: The TCP115's are used in the Dayton Audio MK402's, so you can see what a single woofer is capable of in Amir's review HERE.)
It is indeed a sprinter. It is an Airstream though so already fully finished with no ability to modify anything. It had a crappy subwoofer in an enclosed cabinet (!) which I took out to make room for Lithium batteries. As bad as that sub was, without it the sound was all midrange and treble so not pleasant. I put the JBL S2 in there and it does sound a lot better but has long ways to go to sound really good.
It was a nightmare install, having to take out the seats to place the amp, the entire dash for new head unit, etc.
When I saw Dayton Audio in the title, my expectations were immediately adjusted lower (unlike the sub’s response curve.)
So, this is not entirely fair. I have tested a fair number of Dayton drivers and some of them rival higher end drivers. OK, maybe not Purifi, but I would put their better drivers on par with Peerless, SB and say, lower end Vifa/Peerless/Scan/Seas/SB drivers.
The problem is that this unit isn't one of them, and they sell some very, ahem, budget drivers.
The problem with this unit is it's not one of Dayton's better offerings. Not sure what they were thinking with the design. The math of low frequency SPL says you can't, you know, you just can't get any meaningful spl below 100-200 hz with 4" drivers, even if you have four of them. You really need at least as 10" driver just to get in the door of low frequency extension. A 10" driver has 25 times the Sd of a 4 inch driver. Even if you quarter that, it's still six times less. And that is assuming the same Xmax which is dubious. You need a 10 or two 8"s. I mean, I guess you can count on some cabin gain(I'm not a car audio guy particularly), but yeah, these actually measure about right for the driver Sd and design...
No drivers, not even if they were Purifi 4" drivers, could produce decent bass. The physics doesn't allow it.
My old, old test data, courtesy of the wayback machine.
This is all fair and correct, but shouldn't it roll off well below 400hz even if you're using it with tiny computer speakers?
Not said as a joke: Can folks help me understand why I should dislike this?
All I see is 85 dB SPL from 100hz to 50hz with low-ish distortion. The stuff above 100hz I usually ignore in a subwoofer graph. So for a tiny thing that cost 145$, you could do much worse. Toss in a < 100$ mono/bridgeable chip amp and you have something that fits under any desk and fills out your monitors nicely.
Not sure how accurate this is, as I don't usually use VituixCAD like this.
Most cheap little Class D 2.1 amps that have a variable low pass, have a 12dB per octave filter.
Below (blue) is an estimate of room gain in addition to a 12dB per octave low-pass-filter centered at 100Hz.
I doubt it is all that accurate, but my only point is that it is closer to what the in-room response is likely to be than the anechoic measurement (pink).
Well, that's what I was trying to say. It's not terrible. If you have tiny cube speakers hooked up to your PC and you're looking for a unit that can produce mid 80dB spl in the 50-100 hz range to fill out those cubes then, well, yeah, it kind of works. But I suspect multitude distortion patterns would look pretty woeful and the unit would fall apart quickly if pushed.
Yeah, kind of the definition of mid fi. Mid fi is, well, not terrible. Just kinda mid...
You could take a small 8" sealed sub with a solid class D amplifier, a Linkwitz transform filter in the dsp of your choice, and have a way better unit. Might cost a little more, but not terribly much so.
It's definitely worth pointing out here that the speaker hasn't been 'tuned' to provide a peak at 400Hz as if this was some sort of design decision for sound quality.
The 400Hz peak is most likely a direct result of the way the 4 drivers are mounted in that recessed cavity. This is almost exactly the same as H/U open baffle bass designs. There is absolutely no intention of these to ever be used up near where these cavity resonances occur. It is a passive sub woofer and is supposed to be low passed.
As seen in the impedance plot the intentional bass tuning is at 50Hz. With the given frequency response plot this is also non peaky and well implemented.
There is nothing about this that shows one note bass as the bass alignment is fine. If anything it has an extended bass shelf alignment and those are typically chosen to help alleviate one note bass.
What this is showing is how the raw output of a subwoofer can look without any filtering in place. What this thread has shown is how almost everyone here has misinterpreted the measurements.
As mentioned above this is a slim line compact subwoofer for providing additional bass to tiny main speakers that have no bass to speak of. Add in room gain, or cabin gain if put in a car, and you get something very useful for something so small.
