With this scale the graph is more credible to me, comparing with others that I have from other loudspeakers.
Incorrect presumption.Presumably its users listen only to modern commercial music so badly produced, and then an additional distortion should not be very noticeable, especially with synthesized instrumentation and everything else.
I owned a pair of Dynaudio Contour 1.8 mk II for 5 years.
Then sold it to a friend due to upgrade.
He made the following mods: damped all the walls inside with 2mm self adhesive bitumen sheets. Also replaced the capacitors of the filters with higher grade ones.
Now the sound of these lovely speakers is much better than before.
The only drawback is the lack of a midrange speaker. But it is Contour 1.8 mkII.
This one is also on its way to Amir .Here is the second one...
Here is the REW measurements for the pair...
They track each other very well. This indicates they parts are consistent in quality. newer one is the blue trace.
BUT DID YOU BURN THEM IN? AY(H(D*H@H(*@#HDDIUA!!!!
Putting my kit together now and I've got to say the MDF flatpack is a letdown. I had to sand the fuzzies off the routed back panels as well, just like post #18. Just in general it seems not as nice MDF as the DIYSG kits I've bought, likes to soak up Titebond III and fray at the edges. I'm planning on veneering this pair but I can see how prepping these for paint would be irritating.
Obviously nowhere near knowing how it sounds, and it's no secret the money in these goes to the drivers and crossover, but if this was Babby's First Speaker Kit I'd go with Overnight Sensations, the Baltic birch ply flatpack is just nicer and more idiotproof.
