15 channels... and which DVDs / BLU-RAYs have 15 channel audio....? Even 7.1 soundtracks are rare.
I suppose Dolby Atmos and DTS:X could steer sound objects to all those channels...I'd be curious to know how that would work. Wouldn't the original film sound designers have to specify to the processor what to do with sound objects if 15 channels were available? How would Atmos processor know which sound object to place in a top /rear or top /front / center speaker?
I'm curious also if the $12,000+ one spends on this gizmo provides 8k video capability. Or is that an additional arm + leg + firstborn?
We've moved well beyond channel based audio formats like 5.1 and 7.1 at this point. A lot of the big movies/series have Dolby Atmos object based sound tracks even on streaming services. Instead of steering the object around channels and telling the processor what level each channel should be they make one object based mix.
Then the mix basically just tells the processor where in space the object should be rendered. The AVR will then use the speakers needed to render that object in that particular part in space(your room). Now if you have a 5.1.2 system to work with the AVR will use all those speakers available to render the object best it can. If you happened to have a 9.1.6 system at hand it will render the object with more precision since it has more speakers to work with.
The soundtrack will scale up 24.1.10 I believe so if you buy a movie today with Dolby Atmos and you currently have 5.1.2 for example the same soundtrack on the disc will scale all the way to 24.1.10 if you happen to upgrade to a system like that. So I think it's a pretty smart system in sense. You can re-watch your old content when you upgrade and rehear the same soundtrack but with even better sound.
8K and all of HDMI 2.1 is still beta IMO. As far as I know only Denon and Marantz have AVRs with HDMI 2.1 but now people are finding out that there is some bug in some chip that is needed for certain features to work. This is not fixable by firmware so pretty bad...All these expensive processors move forward slowly due to issues like this and you will not find high-end processors with HDMI 2.1 any time soon I would think..and if they do not all features will work I can almost promise.
After the $4000 mark(Monprice HTP-1) I'm not sure what extra stuff you are getting really in terms of 16 channels(or less) products. The measured performance is worse in a lot of cases and the software is very buggy it seems, reading forums. That is unless you really need 16V out, Dante or some other special feature then maybe Datasat, JBL Synthesis or Storm is the way to go but otherwise it looks like a bad deal to me.
So what I'm saying is that you don't need to spend $12000 to get these features unless you need the higher output voltage etc. And if you want 8K then you have to resort to buying a more consumer oriented product with worse room correction, 2V out etc. And for now all of HDMI 2.1 is basically for gamers.
