Darlington Labs MM-5 Review (Phono Stage)
This is a review and detailed measurements of the Darlington Labs MM-5 Moving Magnet phono pre-amplifier. It was kindly purchased new by a member and drop shipped to me. It has a few options but as purchased, it costs US $199 from the company.
The front panel doesn't look half bad for a budget device:
The back side, not so much:
While the RCA connectors are high quality, the labeling and input power hole are as Dave Jones would say, "how you doing."
I must confess the name Darlington takes me back decades to my childhood when I was learning electronics. Darlington is a simple pairing of two transistors where their gain multiplies almost like magic. I would always have a smile on my face when I would spot it in a circuit diagram.
Here, I am not sure if any Darlington circuit is used or not. Company says it uses J-FET discrete class A amplifier with no feedback. I suspect we are going to see plenty of distortion.
Darlington Labs MM-5 Measurements
With only moving magnet supported, our job here is pretty simple as far as measurements starting with our dashboard:
We have two problems here. One is mains and harmonics which I could not get to change one bit no matter how I grounded things. And quite high second harmonic distortion as we expected. Ranking therefore is quite low:
Company makes up for that partially with good implementation of RIAA equalization:
As noted, there is no high pass filter here so if your woofers are dancing around without making any sound, you know you should have gotten a phono stage with one.
I was really impressed by the high level of headroom available:
Immunity to pops and clicks should be good then.
What distortion there is, is almost constant with frequency which is good:
A design choice was made to leave feedback behind which then resulted in quite elevated distortion. Usually we don't see any distortion spikes in decently implemented phono stages with SINAD completely dominated by noise. Not here. There is plenty of distortion but it is second order so maybe folks can feel good about that. Given the high distortion of the LP media itself, I decided to not be too critical of that and assign some weight to nice headroom and decent RIAA implementation.
Of note, company provides pretty accurate measurements that correlate well with mine. Kudos on that.
Personally I can't recommend the Darlington Labs MM-5. You can choose otherwise with the data provided.
Under NDA?
No. One is broken or seems that way. And the other is a speaker and I need to listen to it more tomorrow before posting.
abdo123
Brussels, Belgium
@amirm
no S/N test?
SINAD is not really that useful since the output of the needle will be much much noisier than the Analyzer’s output.
restorer-john
The headroom (THD vs input level) test is done at 1kHz? 100mV at 1% is not great, but we've seen a lot worse.
martin900
Isn't this like, very, very bad especially with smaller speakers?
Helicopter
Michigan
Thanks Amir.
I am always interested in this category, but so far the only products tested that might compliment or replace my little NAD PP2 are the Puffin and the Duo.
Seems there is no shortage of >$100 products in the category that are outperformed by the $66 DJPREII. This example is another loser.
Bob from Florida
Amir - looks like headroom is almost 30 db at clipping relative to a 5 mv input. (20 x Log (154/5)). How does than compare to other phono preamps you have tested. Also, can you plot headroom by frequency? Something like your multi-tone test for DACs except the vertical axis is in db at clipping. Compared to another preamp with better SINAD but much lower overload - do you hear a difference with critical listening? This may be source material dependent - as is full scale music versus compressed music.
krichard2496
Thank you Amir for the review.
The single-ended Class-A feedback-free gain circuitry is a conscious design choice.
We could have chosen differential-operation of the gain stages and still not used feedback; the result would be around -70dB to -80dB second harmonic distortion.
As it is, we could also 'optimise' the second harmonic and lower it a few dB by trading off some overload headroom. Doing so in our ear leads to a brightened, forward, more strident quality and increases the relative proportion of the third harmonic. Also note that unlike other units which also use Passive-RIAA EQ, our special design avoids an increase in High Frequency distortion due to overload of the input stage.
Third harmonic at ~ -103dB as tested is a goal which we worked hard to achieve. Lastly, unlike some other "no feedback" units, our models have a low-impedance output that interface well with most gear. The residual mains harmonics are NOT related to a noisy regulation scheme; they are induced due to the size of the enclosure, and with A-weighting being typical of the ear's response, are inaudible in normal conditions.
Our listening tests lead us to the current design.
We have a 30 day return option for all clients to audition the unit (or our other higher-end models) in their own system.
Sincerely,
Keith Richardson
Director of Engineering
Darlington Labs LLC
Helicopter
Michigan
Sincerely,
Keith Richardson
Darlington Labs LLC
Interesting. No doubt some people will enjoy that distortion, and that it should be fairly benign. It should sound like some of the common tube based circuits. If it had some pretty glowing tubes on top, it would be more interesting to me. Not sure I would want the noise with sensitive speakers though.
Thanks for chiming in and welcome to ASR!
@AdamG247 can someone get this guy a badge? ;)
AdamG
Debunking the “Infomercial” hawkers & fabricators
Moderator
Reality
Request submitted to Amir for consideration and action. Thank you @Helicopter for bringing this to our attention. :cool:
DSJR
Suffolk Coastal, UK
Sincerely,
Keith Richardson
Darlington Labs LLC
I do wish I could discuss with you on more of an equal level to yourself, but I can't, so profuse apologies..
I do have to ask though, what is all this about low or zero feedback in the audiophile community, when other makers seem to use it carefully (local, global and possibly carefully adjusted amounts of both) and get a superb performance and 'great sound' as well. I'm not a Bruno Putzeys disciple as such, but he seems to feel feedback isn't the enemy it's been made out to be, but he's designing power amp circuits and not to my knowledge, phono stages.
After that possibly too-naive question above, I must congratulate you on a nice high overload margin, as that's one thing that I feel many vinyl lovers aren't aware of - the effects of a phono stage momentarily overloading on surface ticks and splats and making it appear subjectively worse than it really is.
Vini darko
Dorset England
Sincerely,
Keith Richardson
Darlington Labs LLC
Welcome to ASR always good to see manufacturers getting involved.
