Old_School_Brad
- Joined
- Sep 10, 2024
- Messages
- 1,764
- Likes
- 2,338
I think it largely depends on how significant the differences between the loudspeakers are. I have a copy of Toole’s book and looked into the experiment in question. The two speakers, which were almost identical except for having different crossovers tuned for separate markets, were consistently chosen over the other two systems in both the blind and sighted tests by a considerable margin. I won’t directly quote from the book to avoid any copyright issues.From Sean Olive (bolding mine):
"In summary, the sighted and blind loudspeaker listening tests in this study produced significantly different sound quality ratings. The psychological biases in the sighted tests were sufficiently strong that listeners were largely unresponsive to real changes in sound quality caused by acoustical interactions between the loudspeaker, its position in the room, and the program material. In other words, if you want to obtain an accurate and reliable measure of how the audio product truly sounds, the listening test must be done blind. It’s time the audio industry grow up and acknowledge this fact, if it wants to retain the trust and respect of consumers. It may already be too late according to Stereophile magazine founder, Gordon Holt, who lamented in a recent interview:
“Audio as a hobby is dying, largely by its own hand. As far as the real world is concerned, high-end audio lost its credibility during the 1980s, when it flatly refused to submit to the kind of basic honesty controls (double-blind testing, for example) that had legitimized every other serious scientific endeavor since Pascal. [This refusal] is a source of endless derisive amusement among rational people and of perpetual embarrassment for me..”"
http://seanolive.blogspot.com/2009/04/#:~:text=In summary, the,embarrassment for me..”
However, when the test moved to different room positions, the results shifted, and one of the other systems became the preferred choice. As we know, room acoustics significantly influence the sound, so it’s not surprising that certain speakers perform better in some positions than others. Given that preference is strongly influenced by bass response, it’s easy to see how some speakers could trigger room modes and perform worse, while others do better. One of the other systems was a satellite and subwoofer setup BTW.
In any case, the results of the initial test align with my belief that a sighted test, conducted with speakers in the same room and position, can still be reliable as long as the differences between the speakers are substantial. The user mentioned having had both the KEF R3 and a pair from GR Research. While I may be making some assumptions here, I tend to believe that KEF produces speakers with greater neutrality, lower distortion, and less resonance than GR Research. Given these differences, we’re likely dealing with two very different sounding speaker pairs.
I have no problem with his preference for the GR Research speakers. An issue arises when one uses a personal and subjective experience to convince others they're wrong.
