As far as I know.
I’m not sure how you’re suggesting to measure for this, but when I measure at listening position, there’s no resonance at all in the midrange and treble. The waterfall graph is clean. Is this a measurement right in front of the speakers?I have and still own his speakers. He doesn't measure them properly and I have shown this. Here is an example you could have easily found: https://www.audiosciencereview.com/...research-lgk-2-0-speaker-review-a-joke.34783/
This is proper measurement:
This is not:
It only starts at 200 Hz and is heavily smoothed as I have marked. How do you hide problems in frequency response? Smooth them! How do you avoid showing issues in bass response? Don't show that response at all!
Danny doesn't show measurements for distortion. If he had, he would have realized the failure in the design:
86 dBSPL should be walk in the park for any speaker you buy let alone anything called "little giant killer."
Danny loves to show waterfall tests results. Here is mine:
It shows many resonances or as Danny calls "stored energy." His measurements are this:
Much cleaner, yes? Or is it? Here is my measurement again if I change the parameters to hide the resonances:
In listening tests, this was the worst performing speaker I have ever tested. I suggest you watch the video I did on this failing design, both objectively and subjectively:
All in all, I must have spent over $2,000 on his products for testing. All paid at retail prices with Danny not providing a cent of discount let alone industry accommodation pricing.
We also have the disaster which was the X-Voce. Speaker that has massive cancellation in upper bass/midrange: https://www.audiosciencereview.com/...v123-gr-research-x-voce-speaker-review.49563/
Not only this, but the man seriously lacks ethics. You can read the above review thread on how he misled his customers on real problems of that speakers. In a thread about it on another forum, he repeatedly deleted my and other posts and eventually had the admin completely delete the thread. That forum sells that part of their site to companies and they can do whatever they want. To this day, he has not owned up to serious design flaws in that speaker, not has compensated anyone with a fix.
Don't go make claims like this or grab uninformed talking points. We speak with evidence.
Thanks, so the waterfall is meaningless when measured from listening position. And here I thought my speakers were awesome. LOLThere's lots of info on here and other sites on how to measure a speaker and why you need to minimize/eliminate as many boundary interactions as you can to increase your datas accuracy.
Waterfall is mostly useless regardless of what you are doing. Frequency response shows the resonances in the form of peaks already and is not subject to all the parameters in waterfall graphs as I showed earlier.Thanks, so the waterfall is meaningless when measured from listening position.
Here’s a question, why is there so many different driver types and quality levels when most of them (even the budget level ones) could be implemented in a design and achieve pretty good frequency response. If it’s done with low cost drivers and measures the same as a design with the very best quality drivers, at normal listening levels shouldn’t the two models sound the same?Yes, yes and yes.
I highly doubt it, but some here seem to think that the frequency response is mostly all that matters, no?
Implementation and design is far more important than the constituent parts.Here’s a question, why is there so many different driver types and quality levels when most of them (even the budget level ones) could be implemented in a design and achieve pretty good frequency response. If it’s done with low cost drivers and measures the same as a design with the very best quality drivers, at normal listening levels shouldn’t the two models sound the same?
Right for tonality, but if you’re trying to judge a stereo speaker pair for overall satisfaction level, this one speaker test won’t let you hear enough of the performance. It’s flawed and incomplete. And I don’t believe (despite what others wrote in this thread) that just because one pair measures better than another it’s guaranteed the “better” pair will provide a better overall listening experience. Some speakers can image better, provide better transient response and dynamics, plus better detail even if the frequency response and off axis isn’t as perfected as say KEF, which I owned.And that would be what a layman would do, rather than someone informed of research which clearly shows why testing for tonality is superior in mono vs stereo:
It looks like you've realized that neutral-measuring speakers aren't to your liking, and that's perfectly okay. It's your personal preference.Right for tonality, but if you’re trying to judge a stereo speaker pair for overall satisfaction level, this one speaker test won’t let you hear enough of the performance. It’s flawed and incomplete. And I don’t believe (despite what others wrote in this thread) that just because one pair measures better than another it’s guaranteed the “better” pair will provide a better overall listening experience. Some speakers can image better, provide better transient response and dynamics, plus better detail even if the frequency response and off axis isn’t as perfected as say KEF, which I owned.
I experienced it myself KEF (measured great in tests) vs my others models it was boring and didn’t entice me to want listen much. With the GR model I own now, I spend too much time listening, probably not good in a way cause I get less of the more important things done.
The perennial problem of confusing personal preference and objective performance evaluation.It looks like you've realized that neutral-measuring speakers aren't to your liking, and that's perfectly okay. It's your personal preference.![]()
One thing I'll never understand is why this is even a thing in the first place.The perennial problem of confusing personal preference and objective performance evaluation.
'I like these speakers so they can't possibly measure poorly! The tests must be wrongly conducted or missing something important.'
Nope. Just it's just your personal preference. Live with it.
Lack of basic knowledge?One thing I'll never understand is why this is even a thing in the first place.
I don’t think my speakers measure poorly, just not as good as the top models promoted here. It’s the attitude expressed from some here that just because a designer’s methods aren’t the same or lacking compared to a big company like JBL, REVEL etc, with state of the art testing facility they don’t deserve to be considered. I’d bet there’s talented people who DIY in a garage that can build excellent sounding speakers.Lack of basic knowledge?
Not so long ago I suggested some speakers to someone who had very specific requirements.
He found a subjective review of them, the review was damning.
So I found him another subjective review that was full of praise for them.
It didn't change his mind. I said: Just trial them, you can always send them back if you don't like.
But no. Some men you just can't reach.
And then those polls posted on ASR reviews, people vote using only the measurement data and probably most never listened to or owned the speakers, or am I wrong assuming that?
But why would you choose a second rate product?I don’t think my speakers measure poorly, just not as good as the top models promoted here. It’s the attitude expressed from some here that just because a designer’s methods aren’t the same or lacking compared to a big company like JBL, REVEL etc, with state of the art testing facility they don’t deserve to be considered. I’d bet there’s talented people who DIY in a garage that can build excellent sounding speakers.
I also don't use text-book measuring speakers but I don't think that's a big deal.I don’t think my speakers measure poorly, just not as good as the top models promoted here. It’s the attitude expressed from some here that just because a designer’s methods aren’t the same or lacking compared to a big company like JBL, REVEL etc, with state of the art testing facility they don’t deserve to be considered. I’d bet there’s talented people who DIY in a garage that can build excellent sounding speakers.
It’s not second rate and probably put your overpriced offerings to shame. Spare me from this arrogant nonsense.But why would you choose a second rate product?
