GM3
For the record, when Danny had the chance to prove whether his snake oil power cables make an audible difference, he chose to compare 16 AWG speaker wire to his 8 AWG wire instead. And this occurred right in the middle of the ASR power cable review 'controversy'. And he never participated in a controlled DBT or BT for his power cables either. He sure claims that he did, multiple times, but 'strangely' there's no official record about it anywhere. So you'll just have to believe his claims.
Some more knowledgeable in crossovers than me might correct me, but I think the tolerances may or may not matter though. We are talking of quite small numbers, and since crossovers induce slopes, if the components vary by 1 or 2%, the end difference might not be perceivable.
You can also just measure and match them yourself, that way you can get amazing tolerances for low cost. A +/- 2% might have one which is +2% and the other -2%, resulting in 4% difference between the two, whereas if you measure and match 2 yourself, you might get a 0.3% difference. In other words, more expensive doesn't necessarily mean better.
And again, to go back to Danny, I don't think he's ever demonstrated that he can truly hear the difference between his snake oil binding post tubes, or even crossovers for that matter. That would be an interesting test. 2 external crossovers, 1 using regular components, similar to what an enthusiast might build for a budget/normal build, matched or not, and same crossovers with his overpriced caps, inductors, wire, etc.. I'd bet a couple hundred bucks he would fail such a BT or DBT test.
Sometimes, but not inherently.
A €300 10uF Mundorf MCap® SUPREME Classic SilverGold.Oil is +/-2%. That's a bit better than what you normally get from cheap film caps.
But then again, you can find non-audiophile caps with +/-1% ratings at a tiny fraction of that cost.
This is the second time that I have confused
