Danny has a video on ills of using EQ. It has some elements of truth in it, like EQ being listener dependent, but a bunch of other stuff that is just wrong, including measurements with an artificial wall.
I should do a video on it but for now, post this response under it. Let's hope it doesn't get deleted:
Hi Danny. This is a great topic and nice to see you run some experiments. Alas, there are two major problems in your analysis:
1. Above transition frequencies of 200 to 300 Hz, you can NOT trust your single microphone measurements. ***That is NOT how we hear.*** We have two ears and each perceives a different frequency response. You said it yourself: movie a bit to the right or left and the response changes. Therefore, each ear picks up a different response as not only determined by the differing response, but also reflections and masking by your head and body (HRTF). You have to apply full knowledge of psychoacoustics to single microphone measurements to have any hope of understanding what we hear.
If you don't believe me, do your loved ones in home sound radically different when they walk or stand closer to the wall? How about you moving left and right relative to them? They sound the same, right? Same here. Our brain has strong adaptation and learning in how it interprets the two signals coming from each ear.
2. In bass frequencies, in sharp contrast, measurements do show the reality because wavelengths are long so each ear hears the same thing. As such, frequency response errors are clearly bad and must be fixed.You scuff at using DSP to fix these yet you that is the most powerful tool you have. Go ahead and show me what those toy tube "traps" you have in the back wall do in correcting bass frequency response. It will be bad without them, and almost as bad with them! You wasting money on them and they are ugly to boot. DSP on the other hand, can trivially fix the peaks which cause boomy bass that lingers in the room.
Further, pulling down the bass with EQ allows your room resonance to work in your favor: speaker is working less hard so creates less distortion. In contrast, any kind of absorber eats power and energy from the speaker. That is how they work. They convert sound energy into heat, wasting amplification power.It is true that you can't fix the dips easily with DSP as they are mostly non minimum phase phenomenon. Fortunately, they are most benign as they can only change the sound if a note perfectly lands on them. But let's say you want to fix them. Good luck using your acoustic products to impact them. Wavelengths are very large making those products almost invisible to it. You need tuned absorbers which are expensive and difficult to deploy due to sharp dependency on actual frequency response measurements.
As to multiple seats, most people listening in stereo don't care about more than one seat. For home theater, you do want wider seating position and there, you can deploy multiple subs and/or technologies that use all of your speakers to produce smoother response across the whole seating area. Again, trying to do that with acoustic products is futile as you need so much of it to make a dent. And if you did, you would have a dead room no one would want to listen in it.
All of this has been extensively researched and written about. Controlled published testing shows that EQ absolutely increases preference rating of listeners.
