Danny at GR getting bad Talk Back from many of his viewers
That's from the GR Reserach Klipsch RP-600M mod (Amir has measured) isn't it? To me it looks like this particular GR Research mod looks good and also Amir concluded "Overall, this is a job well done by GR Research and I am going to recommend it to owners if they are not inclined to use my software EQ fix.". Original response measured by Amir looked far worth:
Yes, this is one of the earlier Klipsch speakers, and no dispute that the GR upgrade is an overall improvement with the caveat of EQ as simpler alternative.
All this goes to the point about good practice. Not sure about the earlier cases, but the Klipsch tower had known measurements to use a baseline for comparison. Danny should have taken time to compare EAC's measures vs his and then (hopefully) would not have made the same claim (and applied a different fix?). As it stands, the GR results are not credible or trustworthy.
I have to say, Amirs test examination of Danny's Ascend upgrade was amazing. All I can say in street talk is Amir gutted him like a fish. Well done Amir! LOL
While noteworthy that Danny actually considered baselining one of his upgrades, helps if check to make sure you are comparing the same version though.
Here is where Erin chimes in on the GR youtube page....
Looks as though Danny may get a Klippel lesson after all! :)
Danny has acted like he will do some learning and it never happens. It usually devolves into an invite to go to Danny's place and listen, still with no Klippel anywhere near the product! He has way too much to lose by engaging in actually learning about the Klippel and then he would have to admit he doesn't know diddly squat about it and how it works and then tell his audience he has been wrong for over 10 years! It will never happen as that would kill off the mystique of owning a real GR Research crossover mod. What a tangled web we weave when we first deceive.....
Danny post in the comments that Erin's measurements don't indicate how it sounds:
"Commenter: What I would suggest is send in one of your modified speakers to Erin so he throw it in his Klippel machine. Erin is very honest and he will tell you what you say about your speaker is a lie.
@dannyrichie9743​
You have been very mislead. I like Erin, but having him measure a speaker will not tell you how it sounds. It will only show you a level of accuracy. He measured one of mine. It measured great. That still doesn't tell you everything.
I get it, but guess was just willing to grant some benefit of doubt that Danny actually might do what he says. It did not take long for him to renege and reveal his true plan. Here is what he posted later to another member on his youtube channel about Erin’s Klippel measurements…
@dannyrichie9743​
8 hours ago
What they do that is special isn't seen in the measurements, or at least not the ones that he takes. I'd love to have him over for a listen though.
I thought maybe it is interesting to actually visualize the effects of time gating and smoothing. I imported Erin's JBL L100 Classic MKII on axis measurement into REW, used "Generate minimum phase..." to generate an impulse response and applyed various levels of gating and smoothing up to the degree Danny does:
I thought maybe it is interesting to actually visualize the effects of time gating and smoothing. I imported Erin's JBL L100 Classic MKII on axis measurement into REW, used "Generate minimum phase..." to generate an impulse response and applyed various levels of gating and smoothing up to the degree Danny does…
Between the Ascend, the Klipsch tower and this JBL, Danny is trending in the wrong direction. Those last two have not involved Amir at all, so Danny cannot try to blame him for those errors.
:mad: Looks like Danny's old friend & fraudster Mark L. Schifter might be back in the portrait. :mad:
*FYI: It's been brought to my attention that Mark Schifter has a bit of a history. If you want to know more do a search on him and make and informed decision if you're considering purchasing*Vera Fi Audio Vanguard Scout https://verafiaudiollc.com/products/v...
I'd never heard of Vera Fi Audio before, but I'm guessing that we should spread the warning? According to cheapaudioman's video above, even after his 1st charity fraud, he went on to scam/steal others, and like they say in French: "Jamais 2 sans 3". And yep, reddit has a warning scam thread about him, so doesn't look good...
(Danny & Schifter were involved in multiple projects together ex; https://www.highfidelityreview.com/av123-x-statik.html)
Was pricing some speakers online and found Def Tech DM70 towers on sale for under $3000. If you wanted to try a bipolar speaker these are a way better value than GR’s offering. The DM70 also a 10 inch built-in subwoofer. It also provides a switch for tailoring the rear sound. This is a must have in my experience. If you find bipolar is not for you, unlike GR, you can return the DM70s.
Danny was recently whining about the lack of mid-fi offerings but his latest speakers are pretty pricey. Months after launch, still no 3rd party reviews of the NRD speakers either. :facepalm:
On the other hand, one might ask: Which tests—other than those conducted by Amir himself—would be accepted here on ASR?
Maybe Erin's, but after that, the list gets pretty thin.
Conclusion: Amir has to test it himself.
But does he even want to?
Erin has reviewed GR stuff in the past, but Danny already shot down EAC as a potential reviewer.
Am sure Amir would review. Again, is Danny that is the hold out.
Will pay shipping though. Seems just a matter of time before someone gets buyer’s remorse and will loan us one. If I was unhappy and could not return, would be interested in knowing why the speaker came up shy. Of course, most of us would not buy without a fairly impartial review anyway.
I mean a bit of a stretch, but maybe "Sterephile" but honestly even their measurements are just semi-okay to me.
Which more importantly brings up the issue of the lack of decent measurements other than the Two well known to us, and maybe Sterephile.
