Danny at GR getting bad Talk Back from many of his viewers
Given how comparable the AH and EAC measurements are for the RP8000F v2, there might be a few reasons for Danny's ugly one. As his impedance measure is comparable, makes it less likely there is a component issue. One obvious difference is his extra zoomed scaling. Here is how his on-axis FR appears with standard scaling...
Still has a significant (~ 6 dB) droop at 1500 Hz, so is not just Danny's myopic scaling. Looking at EAC's vertical off-axis metrics, it seems likely that Danny did not measure his horizontal on-axis on the tweeter axis. Given 2 solid baselines he could have used as references, he should have known his on-axis FR was off. His "upgraded" frequency response could be just to move the mic on the normal axis! If you look at Danny's vertical on-axis, it is not close to flat either. Could he have just taken both measures initially off-axis? His own data seems to indicate he may have. Danny's story is the Klipsch engineers make speakers with droopy midrange response. If so, The AH and EAC measurements would have the same issue. However, they both show fairly linear response for both horizontal and vertical on-axis frequency response.
This is the review I am referring to from Audioholics:
Ah ok. The one linked previously was for the previous version of the speaker. In any case, as RickS already pointed out, clearly Danny's measurements were not done correctly. Unsurprising, to say the least.
Sometimes I also have the impression that Danny's measurements of original speakers might look a little bit too bad. So lets look at the Klipsch RF-8000F II case and compare measurements of GR-Research, Erin, Audioholics, Hifisound.de and Andrew Robinson (rather of topic here, since it is an room response and not on axis). I tried my best to digitize the data:
Danny's measurement by far shows the biggest suck out in the crossover region. Anyway the vertical dispersion pattern of the RF-8000F II in the crossover region is very narrow as you can e.g. see in Erin's data. A few degrees obove tweeter axis a significant suck out starts. The RF-8000F II seems to come with some feet pointing the baffle slightly upwards. So perhaps slighty different reference axis (e.g. on tweeter axis vs. of tweeter hight) might have been used and explain some differences.
Just to make sure I would not say Danny's measurements are often wrong. Here are 2 examples of KEF Q150 and KEF LS50Meta which match well with Erin's (at least up to 8Khz) and very well with Amir's measurements:
If only he'd take a break from pointless videos and do some ground plane measurements for below his gated ones..
While not disagreeing, on-axis is only one measurement and Danny has his set and it is not the standard set.
Notably, the lack of bass measurements for his own designs is unacceptable (particularly since the GR return policy is poor).
Notably, the lack of bass measurements for his own designs is unacceptable (notably since the GR return policy is poor).
Sure Danny typically just provides basic data
  • 4ms time gated and heavily 1/3 octave smoothed frequency response on axis and a few horizonal and vertical off axis responses
  • 4ms time gated waterfall
  • Impedance
This is significantly less than many serious DIYs do today, which often add/merge nearfield woofer and port bass response, a full set of off axis measurements and CTA-2034 data and directivity plots generated from VituixCAD.
When I was far more into the DIY stuff, I would often do a near field woofer and port measurement and just splice it on the curve. NOT perfect, but it sure would look good.
Kind of what Stereophile does, but my curves looked better.
It's not hard to get accurate info down low. You're supposed to merge close mic with cabinet sim/port measurement. I'm pretty sure Danny would see vituixcad and think it's the devil.
Yep, it seems like Danny doesn’t like modern software.
One example (measured in REW, corrected using the tool by Jeff Bagby if I remember correctly):
Hello there, consumer here. I have been watching GR videos for a while. Usually only watch a few minutes, cause they get boring fast.
He's always has drama vids so that can be entertaining.
I have the Klipsch RP 8000f2 and I always thought if he ever built some crossovers for them, might be worth trying out.
When I bought them for 2000cad I knew I wasn't getting Focal Grand Utopia's, but they sound ok to me. Have good bass and I listen to them loud.
I'm not spending thousands on gear to listen to at 85db.
The guys video on them just annoyed me though. I'm sure you know way more about speakers then Klipsch bud and ur lil giant killers will smoke Jubilee's all day long.
But your sales pitch is making me not want to spend a cent on your stuff.
He always did seem like a snake oil salesman though. (thats how I found this thread, I googled GR research snake oil and here we are)
Even a consumer can figure out a 500$ power cable plugged into a mile of romex isnt going to do chit. lol
And I knew more expensive parts and tube steak connectors arent going to make a night and day difference, but might not hurt?
But after reading all this seems like I might just save the crossover money and put it towards subs or something that will make a bigger difference in sound.
Any ways thanks for the entertainment.
If you listen quite loudly then your speakers are fine. Danny exaggerates small issues so that he can create some kind of fix. It is 99% BS. Your speakers will last a long time and they are great for your use. I say just enjoy them!
I know it's probably some kind of audiophile sin, but I can make them respond any way I want with digital EQ
Yeah, no way I'd even consider buying anything from them, not that I would anyhow given the measurements I've seen, not to mention the things I've been reading about Danny.
And come on man, Ascend Acoustics is a small, direct-to-customer manufacturer as well, and Dave offers a 30 day customer satisfaction guarantee. ..
You can do that when you make a quality product.
I feel he tries to fix one small issue, and creates another possibly larger issue. We all get a lower crossover point to tweeter benefits in dispersion/matching to woofer being better but he does it by increasing distortion of the tweeter and just brushes off any comments suggesting that.
If it was THAT easy to alter, im sure the manufacturers/Engineers would have thought to do this. His disregard for why things are the way they are show, he is looking more for a quick alteration to sell a product rather than a fully honest improvement.
Okay, it’s censorship, and censorship is awful. What should we do about it?
Perhaps start a forum where evidence-based audio reproduction can be openly discussed without the fear that self-serving business interests like YouTube and GR Research will delete a comment that doesn’t fit their business-model. ;)
