@JBoulter11
13 days ago
If the LLM did even some of the tests you’ve mentioned here, please share the code it used to do those tests and the graphs and charts that display the results. If you just put the clips in as a prompt, then I’m sorry to tell you this but ChatGPT didn’t do any of that analysis, it just lied to you and said it would. LLMs can’t do those kinds of things on their own. They can write code that could be used to do those things but prompting an LLM is not equivalent to running those tests. :\
@thebigds
6 days ago
@JBoulter11 seriously, it takes only short research to understand that ChatGPT is not capable of performing any of these analysis. It’s just hallucinating all the results.Also, the fact this guy recorded two audio files and put them to a survey to ask whether there’s a difference, but he didn’t also immediately null check it. Also does not randomize the files at all just feeds the in, the filename says which system it was.Nothing blind about that! I have a hard time taking this guy seriously at all.
@johito82
3 days ago
@thebigds just ask chat gpt about what is can do in its analysis of a waveform “Short answer: yes — waveforms can give insight, but they’re only one small part of understanding sound quality in an audiophile sense.They’re useful, but incomplete. [...] All the stuff about better imagining micro dynamics and detail are hallucinations
@iloveg25
11 days ago
Audioholics made a video long ago, with amazing lab equipment, and found absolutely no difference in the signal output, as a result, everything being equal, including the signal that comes into the speakers, nothing will be different. The difference has to be measured in the signal, because the changes are electrical only, and there should lie the proof, nowhere else. No change in signal output, no change in audio, and no, power cables and power conditioners don't make a difference.
@ PowerGuyMark
12 days ago
With all due respect I don't really care for the way the conversation goal posts have been moved. Danny is well-known for preaching the gospel of ridiculously expensive speaker connection cables. That's a different discussion than giving electronic equipment a good source of power. 14 gauge lamp cord causes zero problems 98% of the time. On long runs 12 gauge. I do like the idea of you bailing your friend out. Show us the data of the in room results. A power conditioner is totally different topic. I don't have any doubt providing good clean power should be done but show us the data.
@jimallen1485
12 days ago
@ PowerGuyMark I find Danny is generally full of crap and Paul over at PS isn't far behind.
