I got the feeling that you are Dave.
I love that idea. Simply love it. I would be in-line to toss in a few buckeroos to that effort.In the youtube comments, Danny Ritchie is claiming that there is some advanced stuff inside, and he refused to show gut shots claiming that this would reveal the intellectual property of the designer. Ludicrous, really - if it is possible to reverse engineer it, then they should file a patent to protect it as anyone can open the box if they have it on hand. If it was truly some esoteric circuitry then all the more reason to protect it by legal means. Whereas if it's a simple passive circuit that's easily DIY-able (as seems more likely), then it's understandable that he don't want to reveal what's inside, instead resorting to a lot of smoke and mirrors to divert attention. I think the ASR community should crowdfund buying a unit for teardown, that would be good entertainment if nothing else.
@RickS, that is a 10A at 250VAC IEC socket, and likely 15A at 125VAC. Since it runs standard household 110V, I don't feel this is misleading at all. More often than not, Dave preferred the more solid connection of the 20A IEC, but cord availability was less accessible to most users.
As to the UL, fuses, etc; isn't this another case where your electronic components should have that taken into account already and not needed here? It does isolate the AC wiring as required to protect the end user, but i feel a fuse would be a welcome addition. I have a heavy Tripplite suppression unit between it and the wall, and outlet strips with breakers plugged into it. Not that anyone else uses it how I do.
Or maybe a Danny sock-puppet account?
I actually came here looking for a discussion of the related New Record Day video and the associated A/B files available for download.
He is a long standing ASR member and not a GR shill.
Thank you, some of the comments are definitely from left field.He is a long standing ASR member and not a GR shill.
NOTE: All members here should stay focused on technical facts and avoid personal accusations or attacks please!
No doubt that it is BS. But an analysis of the WAV files for actual differences would be interesting. Some folks have reported level differences, but I doubt the hi-jinx end there. NRD's reliance on ChatGPT was bizarre.The GR video (naturally) has a link to the NRD effort.
The YT comments on the NRD effort are more negative than the GR ones. Along with his flawed test methods, one commentor basically points out how the NRD testing seems too conveniently timed to the GR product launch. If you want to dive deeper, go ahead but seems the BS flag has already been thrown on the NRD test.
I am one of those who looks at @Wolf somewhat askance. If I have wronged him in any way, please forgive me. However, please hear me out before passing judgement.
In the first place, there have been many examples in the last few years of "sleeper" accounts, where the member has a join date that goes back several years (in this case, 2020). Their activity seems to be innocuous, and then BOOM! ... all of a sudden, they engage as a troll. So "member in good standing" doesn't always count for much; sometimes yes and sometimes no.
Secondly, @Wolf has only 719 posts in slightly over 5 years. That's certainly not a crime. However, it is suspicious, in light of what I've described above.
Mentioning that "Dave does this" and"Dave did that" is very odd. Repeatedly talking about "Dave" in the third-person omniscient (so to speak) is highly suspicious.
There exists a certain style of "falsely disarming" comments. These can be things such as, "I was just asking a question, that's all", or, "All I was doing was telling you what happened to me". These are not absolutely 100% signs of a troll, but IME trolls use them more than run-of-the-mill posters.
So the reason I was suspicious of @Wolf was more a case of a number of small indicators rather than some sort of huge, obvious offensive post.
As I said above, I apologize if in any way I have wronged @Wolf. Perhaps, in reading this he will understand why some of us doubted him.![]()
OK.Fair point Jim! Notably lately we had a string of hijacked older accounts...
Will let @Wolf explain himself but bear in mind, we all have our biases and not every ASR member is an experienced electrical engineer either.
@Wolf explain yourself! ASAP. No more obfuscations or prevarications please.You can't learn anything without trying or measuring it yourself, unless you know *everything* about the item in question and can make a valid conclusion with knowledge already acquired. Being dismissive does nobody any favors.
oh geez. You’re right. The marketing speak could totally be understood as “we made a 40 amp capable 720 mF lowpass filter, but you can only use it on a 10 amp circuit.”OK, it seems to me based upon what the box is supposedly doing, you get a substantial box with some common electrical plugs. Also Inside the box you probably have 12 or 10 gauge wiring that has some caps across the hot going to neutral. That would seem to do all that is claimed. Now $1600 for a box of MDF, 8 wall plugs and s few caps seems like a LOT of money. The simplest easiest thing to do is take the top or bottom off the unit a take a photo of the interior and post it up. This should be a VERY simple and easy thing to do. Then Voodooless or Amir can tell us exactly what is in it and how it works. All this conjecture when a simple opening it up will answer everything. My opinion is just caps inside.
Unless I'm misunderstanding what you're talking about here, that's not how it works. Amperage ratings don't change based on voltage. 10A is 10A regardless of if it's 1V or 10000V. You'll get different power, obviously, but that's besides the point for an electrical rating.@RickS, that is a 10A at 250VAC IEC socket, and likely 15A at 125VAC.
