Now I need meds and possibly alcohol too. That image is just stuck in my brain...........it hurts.In Speedos. Both of them.
Dr. Who will tell you, time smearing is a horrible thing. If he says it, it is a fact!We should be less sarcastic. Time smearing is serious business!
Amir, is right on target. Production quality can be all over the place. That is one reason I am a supporter of Buckeye amps. He has fine tuned his assembly and soldering to near perfection! Honest builders are always worth supporting.That's a good point. Soldering is even harder when dealing with these high thermal mass components in a crossover. You need to have the proper soldering iron, tools and techniques to do it right. I have actually had speakers sent to me that came from factor with cold solder joints and such that had become disconnected!
Flying inductors can be very dangerous. If you take an inductor to the eye, you could be severely maimed. Danny is looking out for your health and well being. Oh, there goes another one, an inductor just flew off my bench and hit the wall. I need safety glasses.......His accent is the best thing about his videos.
I did watch the first ten minutes and he does talk some sense until he gets into criticising the brass binding posts, use of steel screws, and that the inductors are only glued to the board and could 'fly off' - and then I started losing interest.
Not to mention swinging chokes.Flying inductors can be very dangerous. If you take an inductor to the eye, you could be severely maimed. Danny is looking out for your health and well being. Oh, there goes another one, an inductor just flew off my bench and hit the wall. I need safety glasses.......![]()
Those were just a good way to catch something.
Another important thing when it comes to solder, is getting the right type.
Roofer's and plumber's solder won't be a great choise, if that's what you mean
The fancy gold/silver stuff doesn't do squat in terms of sound. It does have a lower melting point, making it somewhat useful for temperature sensitive applications. Although, passive crossovers don't exactly fall in that category.
Bad/cold solder joints is the only thing that can affect the sound, so high quality industrial electronics solder with high quality flux (the kind that really loves to eat brain cells) is the way to go, if you ask me. If you aren't a cheapskate, you can even get lead-free solder that's easy to work with.
I get your point, but acid core and solid core solder doesn't make much sense in electronics applications.
For those who have these Jamos how do they know if their tweeters in their Jamos are good enough to invest in Danny's expensive upgrade kit?Ok, I’ll share as I plugged my nose, muted the sound and used closed captioning…
This latest Jamo video appears to be an rehash of the first one. Maybe why he called it Round 2 although is the third post. The second one was misleadingly claimed it was about resolving the earlier issues. In this one, Danny simply leaves out the ugly output mismatch from the earlier one. Looks to have been done to allow him to claim he fixed enough to post the upgrade kit.
Is it possible to generalize and say that old speakers with tweeters that have ferrofluid in them should be filled with such fluid?I don't see it.
For instance, he sells a mod for the RP600M:
Amir tested it:Klipsch RP-600M Upgrade Kit (Pair) | GR-Research
gr-research.com
Danny measures them, and aside from his large smoothing they measure bright, and are line-on-line on top of Amir's measurements:![]()
GR Research Klipsch RP-600M Upgrade Review (speaker)
This is a review of a Klipsch RP-600M which has been upgraded to a new crossover, binding posts and "No Rez" by GR Research. The kit costs US $244. OK, so there is nothing externally which is different. :) I can't open the unit to show the different bits but here is the back with new binding...www.audiosciencereview.com
I've adjusted Danny's to the same approximate scale as Amir's to allow comparison. The dotted line is a trace of Danny's data overlaid on Amir's.
His measurements, aside from smoothing, scale, etc. look fine.
In the case of these Jamo speakers, he ignored the obvious.
Funny, I have Seas TC25F002, about 20 years old. The ferrofluid dried out as they do in this era of Seas tweeters, and they started sounding and measuring just like the ones Danny showed. But I didn't get distracted and haul out the crossovers and replace the binding posts. I replaced the ferrofluid, it was much cheaper and actually fixed the problem.
It's so odd that Danny, with his supposed speaker guru experience, doesn't know about common issues like this.
if they sound okay I'd leave them be, you can create more problems than you solve.Is it possible to generalize and say that old speakers with tweeters that have ferrofluid in them should be filled with such fluid?
How much liquid is needed to fix two tweeters? I mostly wonder if it's worth it.
I did a quick google. AlegaFerrofluid - 10 ml, 200 SEK /$19. Is it a good price?
Edit:
I know, worth to one person but not to another, so I guess it's subjective.
Not sure I have perfected high mass soldering as yet but suspect the answer is larger soldering tips.
I thought more along the lines of filling up, changing to new oil for the car engine to increase its life span. Perhaps the same principle can be applied to this type of tweeter? Or not ?if they sound okay I'd leave them be, you can create more problems than you solve.
There's more than one type of ferrofluid so if you are set on refreshing it I'd try and find out what exactly they used first of all.
