Pearljam5000
- Joined
- Oct 12, 2020
- Messages
- 8,336
- Likes
- 11,224
Anyone identifies the driver?
15 inch coaxial driver
The new 15CXN88 has dual-pleat.The odd surround configuration (only two "rings"/pleats) isn't familiar to me... but this B&C 15" coax looks kinda, sorta similar, albeit with an undoped (or differently doped?) cone.
B&C 15CXN88 15" Neodymium Coaxial Speaker 80 x 80 Degree
B&C 15CXN88 15" Neodymium Coaxial Speaker 80 x 80 DegreeB&C Speakers' 15CXN88 15" coaxial driver combines a powerful woofer and high output horn tweeter into a convenient compact package. By using a massive neodymium motor, B&C allowed enough space to use a huge 3-1/2" voice coil on the woofer...www.parts-express.com
Leave it to Mark Levinson to add the dope.![]()
Thanks!!!The new 15CXN88 has dual-pleat.
15CXN88 8Ω - Coaxials - B&C Speakers
www.bcspeakers.com
Parts Express seems to have the wrong picture, instead showing a 15CXN76.
As the marketing blurb says, "Based on new pro audio speaker driver technology, Anton’s 15” woofer with coaxial compression driver tweeter simply won’t come near clipping with even the most demanding recordings."
I tend to agree the customer won't likely want to operate these near clipping.
For $760 per driver, I have to pass on the Antons' massive markup. Most DIY struggle with complex cabinets with many openings and good-looking grilles. Seems like Daniel Hertz also struggles with these things, resulting in his DIY cum Levinson product.
I wonder if these use B&C's crossover for $135 each:
Or if they opt for some wonky 6dB/octave electrical crossover with fancy caps and coils, perhaps even some cryo action.![]()
FBCXN88 8Ω - Crossovers - B&C Speakers
www.bcspeakers.com
It looks like a fun project for $1500 plus some wood for cabinets.Thanks!!!
US Speaker's site looked like a two-ring pleat, but I opted for PE's link & images 'cause it was easier -- and I am nothing if not lazy!
B&C 15CXN88 is a 15" coaxial speaker - B&C 15CXN88 15" coaxial speakers - B&C 15" high power lightweight neodymium magnet coaxial speaker for fullrange systems and stage monitors. B&C 15CXN88 coaxial speakers available now.
B&C 15CXN88 coaxial speaker for replacement or upgrade. The B&C 15CXN88 is a 15 inch coaxial speaker with 1,000 watts program power handling. The B&C 15CXN88 is a high quality coaxial speaker. A complete line of B&C speakers for DJ’s, Bands, and Sound Reinforcement. B&C 15CXN88 coaxial speakers...usspeaker.com
I guess the markup is for that incredibly exquisite cabinetry in the case of the Anton, eh?![]()
$1 078,13\pcs - quite affordable driver for DIYing desktop speakers https://www.audiosciencereview.com/...8-point-source-full-range.60035/#post-2201632For $760 per driver,
Looks a lot like https://sica.it/prodotto/15-cx-3-pl/Anyone identifies the driver?
More likely than B&C 15CXN88. Check and compare the screw hole design:Looks a lot like https://sica.it/prodotto/15-cx-3-pl/
Edit:
Similar diy version has been around for almost 10 years with B&C coaxials
Kaiutinrakennusohje Piste - 8-, 12- ja 15-tuumaiset hifi-PA-koaksiaalit - AudioVideo
Jaa artikkeli: 191 Shares Facebook 191 Twitter LinkedIn Lisää Kaiutinrakennusohje Yksisilmäiset veljekset herätti hurjan paljon kiinnostusta. Niin paljon, että kun Yksisilmäisissä käytettyjen Eminencen maahantuojalle tarjottiin italialaisen B&C-elementtivalmistajan maahantuontia, he kysyivät...audiovideo.fi
Edit:
And it's not even good build the drivers are not rececessed (should be done at least for the mid for diffraction reasons) and that tweeter and horn looks like a very generic cheap plastic thing. Even if it's not, for that price you expect a better look (I do certainly)View attachment 490176View attachment 490177
40,000 is actually cheap
The M1 costs €400,000(with the Amp)
It would be nice to see this covered with black carpet, like old hairy JBL JRX series.
Totally! They would be awesome in the back of the pickup truck!It would be nice to see this covered with black carpet, like old hairy JBL JRX series.
