Of course you can always buy the
smaller and more affordable version for your home entertainment system
Regarding solderdude link, the relentless amplifier is the model for the kid's room !
The DarkBlock is for the dedicated room. (Darth Vader main setup in the Death Star)
https://www.onlycreative.it/products/darkblock-24000
DarkBlock
Futuristic and absolutely Extreme Performance Amplifier
awe-inspiring 24.000watt! exactly as you would imagine!
DarkBlock
Having at disposal and operating this device, it may be an absolutely thrilling experience: it “comes to life“ opens and his shape that changes completely, foresees the Power of its Performance
It is not only a technical and functional tool, but a work of art that fascinates and involves in its articulation.
Reveals the black side of the Power
It is undoubtedly a new and fantastic combination of sophisticated technology and artistic avant-garde that has never before been applied in the field of high-end audio devices. Having this operating device is a thrilling experience. It is not only a technical and functional tool, but a work of art that fascinates. It is fascinating and indescribable which means, instead, it must be experienced.
The external structure is made of aircraft aluminum and the openings or connections are not visible from the outside, and if he or it is switched on, we feel the dark side of the its Power, which you just have to experience personally. When turned off, it is an impressive black 12-sides prism (WHD) 1.25 x 1 x 1.25 m (49.2" x 39.4" x 49.2"), 800 kg (1.764 lb), but its structure changes completely once the device is turned on 1.85 x 1.3 x 1.85 m (72.8" x 51.2" x 72.8"). It is divided into four distinct sections to reveal all the electronics at a glance. Suddenly you have the impression that you are looking into the technology space!
This unquestionably gorgeous state of the Art Amp features: power input 230/400V 50/60 Hz 120 Amp(400V), 3 x 16 kW triple-insulated toroidal transformers, 8 ceramic diodes 1600V/400A, 54 Kendeil aluminium electrolytic capacitors 6800uf 160 Volt, 528 high current bipolar transistors, 12 analog (RCA/XLR) inputs and six digital, 12 output channels, and 96 speakON connections. It's capable of producing an awe-inspiring 24.000 watt rms at 8 ohm class A/B, distortion: THD+N 0.002%, frequency response: 20 – 30.000 Hz - S/N: > 115 dB (20 Hz - 20 kHz A-Weighted 8 ohm) - Input sensitivity: 11 dBu / gain 30 dB. (the specs show output configurations of 6 x 4.000W rms or 12 x 2.000W rms). The sound really must be experienced in person. However, it is quite easy to imagine how the "DarkBlock" sounds before being able to audition it: one look at the amplifier is all it takes "Purity and Power" exactly as you would imagine. The "DarkBlock" is monstrous in all respects: it’s massively sized, heroically engineered, but it flies with powerful yet delicate wings – it conquers any, and I mean any, speaker load, and with transducers of equivalent stature it can convey profound sonic beauty. Available in 3 different versions (
DarkBlock 12.000), both in terms of size and performance, assembled to order and five years warranty against failures arising through faulty workmanship and materials
https://www.onlycreative.it/images/pdf/DarkBlock.pdf
