Mike_Trueman
- Joined
- May 9, 2024
- Messages
- 648
- Likes
- 518
Is there much difference between the Noire X and the E3?
It depends on many factors. Let's say for me E3 is 10% better than NX, but those 10% are between almost perfect and completely perfect. Of I could afford E3 I would buy E3. If I could afford both I would buy both, E3 for home use and NX on the go. E3 has a bit more neutral and detailed sound. But in my opinion both have so much details one probably hit either hearing limit or source/record. If you have to choose one I'd recommend to listen to them, both are great but some people prefer NX to E3 and vice versa.Is there much difference between the Noire X and the E3?
I'm listening right now to the SMSL D6 (not D6s), if you can find one it's a great little DAC, and has USB-C input.
But if you get another DAC, with regular USB input, you can just buy an adapter to USB-c.
They break sooner. It's not considered as reliable.There's really no reason "new generation" DAC/Amps shouldn't have USB-C ports.
NX is a really, really nice headphone but it’s not really suitable for on-the-go IMO. (Never heard E3.) The way it folds makes it near impossible to fit into any reasonable briefcase, and Gorilla or not the sides are still glass.
Hi,We resolved the first issue in September production, the second was last month (it's far less common but it did need to be addressed). The second issue potentially affected other models (it was the Molex connector not holding as firmly as it should) but we have only seen two fail in the field, to my knowledge.
Inventory can take time to get through a channel, since it ships to distributors then to retailers then to you. I assume Thomann had stock they're working through but they buy through distribution not through us and of course I have no idea what their inventory situation is. I can't guarantee you wouldn't get another unit from Aug because what is in stock and where is out of our control, but it gets less likely every day. As I noted, should you have a problem, especially in Germany, we usually just replace it which unit gets sent back to us by the distributor at a later time.
The primary imbalance problem was specific to the A2/Noire driver and doesn't exist in our other models.
For storage, I'd rather use a HP stand or a bigger case so that it is not necessary to plug and unplug the cables every time.Question for others - I am constantly removing the cable ends at my desk setup, folding the headphones up and putting them back in the case. Will this cause excess wear and tear on them over time? I am very careful when I do it.
My experience with its predecessor, the Aeon 2 Noire, is zero hours of burn-in.There is a paper inside that says between 50 and 100 hours burn-in period. I hope the sound will not change.![]()
And mine with the Noire X.My experience with its predecessor, the Aeon 2 Noire, is zero hours of burn-in.
Should i use HPA gain low or high for best sound on my amp?My experience with its predecessor, the Aeon 2 Noire, is zero hours of burn-in.
low gain unless it struggles to get loud enoughShould i use HPA gain low or high for best sound on my amp?
More distortion on high gain?low gain unless it struggles to get loud enough
I select the amplifier gain that gives me plenty of headroom for volume control. I can’t tell any difference in the sound when I change the gain setting, apart from the obvious increase in volume.Should i use HPA gain low or high for best sound on my amp?
they’re usually not worlds apart, but most devices have slightly more noise+distortion on higher gain. certainly more where that’s the case than the other way around. so if you can use low without volume issues, then it’s typically better to. also gives you a bit more usable room on the volume knob.More distortion on high gain?
It should be but given the brand's history please test to the best of your ability.Hi,
I've purchased a unit from Thomann in EU. Initial impressions are excellent!
The date in the certificate is Dec 4th, 2025.
Can I assume both issues are resolved?
Thanks.
