- Joined
- Mar 1, 2021
- Messages
- 3,031
- Likes
- 6,515
Darn those pesky clairvoyants!
Ha, you don’t know it yet but just wait for your new headphone release next Xmas………..I see…..I see…….I see a Dan Clark ultra portable with Bluetooth.
Is that true?I've got good news for you. The new Noire X is probably pretty close to the E3 for half the price.
Is that true?
Hey guys, just registered after lurking on this thread for a while.
I was looking to buy a pair of closed back cans after I sold my HD660s due to open backs not suiting my situation. I first bought wireless Focal Bathys to cover both work calls and music but wasn't impressed with neither aspect.
Then I started looking for a proper pair of closed for music. After a lot of research, based on comments on this thread and other reviews, I bought a pair of E3s blind.
I have them only for a couple of days, and I am very impressed!
I'm running them with Aune S17Pro Evo amp and Chord Qutest DAC, streaming via Roon.
They are hard to drive for sure. I tried them first with my Naim NAC332 preamp and how they call it their integrated 'state of the art headphone amp', but it was comical how bad it sounds.
Obviously, I then bought the Aune and I high gain them for a very pleasant experience. Only running them properly for a day or so and volume on Aune is now around 35 (of 63).
Not EQing them, but I'm interested in Roons OPRA EQ. I see there's 3 presets for E3. Anyone tried those?
Ah ok so better to do it manually. Thanks ChagallOPRA EQ is just a convenient way to EQ headphones in ROON. You will get the same result if inputting values manually. But manual has an added benefit, because you can adjust EQ to your liking.
And yes, E3s are phenomenal!
Yes, I'd start with @oratory1990 suggested eq and play around with the bands he suggests tweaking for different areas of the FR https://www.dropbox.com/scl/fi/edy1...o-E3.pdf?rlkey=mbgnwieany9q3p60jlvhqjxxa&dl=0Ah ok so better to do it manually. Thanks Chagall
Great stuff, thanks for sharing @Jimbob54 !Yes, I'd start with @oratory1990 suggested eq and play around with the bands he suggests tweaking for different areas of the FR https://www.dropbox.com/scl/fi/edy1...o-E3.pdf?rlkey=mbgnwieany9q3p60jlvhqjxxa&dl=0
You can also use OPRA (Headphone EQ in the Roon UI) and apply a PEQ over it. That might be easier for a lot of people. For example, I use the OBRA EQ for my DCA Expanse headphones and give a bit of a bass boost on top.
Depends on how much money you want to spend. These new headphones are all quite expensive compared to the older ones. Personally from my Aeon Gen 1 to the Stealth.... I wouldn't pay the difference. Instead I bought an amp with tone controls so I can add in the bit of missing bass when I want it. Otherwise they both sound very close to each other.Is the E3 a worthwhile upgrade compared to the Noire X?
The 45CA presents a different picture.Be aware that the E3 has a lot less treble:
The B&K 5128 is closer though to an average ear from geometry and acoustic impedance, but maybe you are lucky and your is closer to a 45CA.The 45CA presents a different picture.
