Dan Clark E3 Headphone Review
Rate this headphone:
    Votes: 5 1.9%
    Votes: 11 4.2%
    Votes: 39 14.9%
    Votes: 207 79.0%
Interesting. Especially since some said the E3 does "everything"
I thought the E3 could even be transformed for everything, e.g via Equalizer.
That’s the same reason I bought it! I think that they mean it is a very good all-rounder.
But Stax SR L700 and LCD5 for example have better resolution. He1000, HD800 and SR L700 have better soundstage. SR L700 has very good imaging.
Tonality-wise, CX works for vocals. Focal Utopia low-midrange bump can sound as dynamic bass…
I still have to find the perfect headphone. Also because some of the above are tonal colorations that can’t live together.
EQ works but I am not using it to switch from one tonal balance to another. Maybe it’s just laziness
Reactions: DEF
But Stax SR L700 for example has better resolution. He1000, HD800 and SR L700 have better soundstage. SR L700 has very good imaging.
I think it would be interesting to hear from somebody who equalizes the E3 if they can transform into an CX for instance - to be comparable or better.
If not, I would also start collecting Headphones.
I would rather have one thing.
About Equalizer - I would set them as shortcut in Linux - software-side - via pipewire. That's as immediate to the sound driver I can get.
OR I run paid software.
Don't forget this unit is glued a LOT and maintainability is a tough call.
And it needs a exact fit on the head, or it will sound off.
For this reason alone I am gonna pass.
I thought about the Audeze LCD-5 instead but it appears that this one is not for 'fun'
@Dan Clark
I accidentally dropped my DCA E3 from desk height. It hit one of the metal legs of my office chair and the wooden floor, making a nasty sound.
Externally, there isn't a single scratch, crack, or bend that I can see. And I *think* that they sound fine. But it's my most expensive audio purchase ever and I wonder: could there be any internal components that are prone to damage (cracking, jolting out of place, etc.)?
Thanks
@Dan Clark
Thanks
Unlikely.
The membrane is so light it almost doesn't have any "inertia" (on obvious simplification, but you understand what I mean).
Unless something breaks or moves in the frame, you should be fine.
EDIT
I was thinking electrostatic, but this one is planar magnetic. My bad.
If the membrane is unlikely to be damaged from shock, the magnet is a different story, maybe.
Unlikely.
Also they used so much glue in similar models that it's kind of impossible for the seal to break or things to move a massive amount.
@Dan Clark
Thanks
If there were an issue you’d know, problems are obvious distortion, gross imbalance, noises etc.
Thanks, all. I think they're fine then. Can't say the same about my anxious mind, though...
I'm surprised there isn't a scratch or dent on them. Amazing build quality!
Can you try a different height next time? :D
Would be fun to see just how sturdy they are.
And maybe @Dan Clark supports you for this endeavor.
If it was half the price, I'd be ordering one now. As is, still a bit too expensive for me, but definitely a step in the right direction(and definitely something I'll be scouring the used market for in a couple years). Impressive that there really don't seem to be any compromises.
I've got good news for you. The new Noire X is probably pretty close to the E3 for half the price.
We do a drop test on products and the E3 survived a 12’ drop onto porcelain with just a dented chassis. Not that we suggest trying this, but it is part of development.
Amazing! Truly the best headphones not just in measurable performance but also in build quality :D
Thank you Dan, that puts all my remaining doubts and fears to rest.
No way mine got damaged from table height onto wood / office leg chair, then.
Whats ' ? Is that the same as " (inch) ? Please note those characters are different. Single and Double quote.
As you'd guess, my office has a number of amps and cables connected to headphones on my listening station, and it's not uncommon for me to catch a cable with my armrest and whip it off the table and to the floor. Only once out of many, many drops did I damage a headphone; the metal chassis got a small dent hitting the solid metal base of my chair.
Having grown up in the USA and being an engineer, believe it or not I know the difference in notation. :)
' as in FEET. We drop test from a balcony to our lobby. A 12" test wouldn't be great for much except ensuring a chocolate bar wouldn't break.
Good to see the meta material being implemented on a headphone half the price of the Stealth/Expanse, still too expensive for myself at the moment so I’ll wait for the updated Aeon Noir at the £1k price with meta material at the end of 2024………………please ;)
HOW DID HE KNOW?
HOW DID HE KNOW?
What can I say? :D , my mother comes from a very long line of Colquhoun (pronounced Kuh-Hoon) highlanders here in Scotland and my great-great-great gran was known to have a bit of second sight so perhaps it’s in my genetics.
Or an educated (hopeful) guess ;)
