Dan Clark E3 Headphone Review
Rate this headphone:
    Votes: 5 1.7%
    Votes: 11 3.8%
    Votes: 46 15.9%
    Votes: 228 78.6%
That's true re loudspeakers. I don't own any Genelec, but I think of them as technically the best, and they're still really quite expensive, so I think speakers have a fair ways to go for that excellent performance to trickle down in price over time. Perhaps great speakers are more challenging to make to a tight "good value" budget than headphones. The thing with headphones is they're already at lower distortion than many speakers and they're very receptive to EQ, unlike speakers, well at least in terms of significant EQ improvements. And you've obviously got your E3 & Stealth as some really good Harman tuned headphones that are sort of the pinnacle of Harman measured success albeit at the high end of headphone pricing. I mean I can see room for more affordable versions of measured excellence in headphones, but in terms of absolute sound quality I think we're at the limits for fixed target curve headphones - so that was more the angle I was going in my initial question.
There are also much more affordable, Harman tuned headphones like the $300 Audeze Maxwell (not to mention a bunch of super cheap IEMs).
I'd love for Amir to test the Maxwell and go into what differentiates headphones when they are all tuned to the Harman curve!
A super quick Google & I couldn't find any GRAS measurements of Audeze Maxwell (I found the Resolve B&K though), but for sure there's some super cheap IEM's that nail Harman or with a tiny bit of EQ (Truthear Blue I found very impressive). He may find that various headphones sound slightly different even when he's measured them & EQ'd them to the same target, I'd expect them to be still slightly different. But yeah, my initial point was that I think we're already at the best sound you can get for a fixed target curve, I don't think there's much more to explore when it comes to fixed target curve.
Got them almost a week ago and still somehow the treble is missing most of the time :(
Treble is missing on E3?
Did you center them horizontally and vertically on your ears? What is your reference - what headphones did you use before? Did you unknowingly applied some EQ?
I used Aeon 2 Closed for a few months a year ago and they sounded great. I returned them under warranty in February and got Moondrop Stellaris in the spring. Which I used every day until I got the E3 in the middle of summer. And now I don't know what's wrong, maybe my ears are used to that high treble level of the previous headphones and because of that these now sound strange.
Yes, I noticed that the sound gets distorted when the fit is wrong, now I align them on my head when listening.
No, any EQ's are off, I tried turning them on and if you tweak the treble it sounds nicer
That’s a surprising graph from MoonDrop who’s well known for following their VDSF target curve. Here we get a V-shape with a serious upper treble peak. It’s essentially bass and sheer upper mids with a dose of piercing treble. If you’re coming something more neutrally tuned, the Stellaris is going to be painful. I needed to listen to it on and off over half an hour to acclimatize. With the right tips and an adjustment (i.e. brain burn in) period, it becomes tolerable. Though it’s still… problematic, to put it lightly.
And now the situation is the opposite. Although I remember when I first got them, I didn't like their sound either. But after a while, I got used to it.
That's it! Stellaris have booosted treble:) E3 has the more correct response, just give it time for your brain to reset.
I can safely say this: almost every headphone I think “I don’t know where to go from here” when we’re done, but then ideas happen and…
Yep! There are still so many small areas for improvement. Your headphones really set the standard for what correct tonality should be like. Hope you have a surprise flagship for SoCal CanJam! Stealth would've been so perfect if it could have been as efficient as E3 and an improved perceived dynamic range better than the E3 :)
Would upgrading to the E3 from my Aeon Noire be a worthwhile investment? Probably could find a shop that offers trade in if used equipment:)
Subjectively, E3 is more preferable than Noires and puts you really close to Stealth's sonics with Stealth being a smidge more preferable than E3 for my tastes. To me the delta between the Noire and E3 is more than the delta between E3 and Stealth, and the delta between Noire and Stealth is very, very noticeable
Well that's good, I like your approach, but I remain a bit sceptical, but I'll always be curious re what you come up with & the various headphones measured here on ASR.
How close would it be to the E3 if the Noire is EQ'd, you think? Reason I ask is I'm thinking of buying a Fiio R9 that has a 10-band PEQ feature to match with my Noire first, before considering an upgrade to E3.
If all three headphones are EQed to a target, the delta between the three would be subtle as expected
Reactions: RJO
Especially if they're all based on the same earcup/pad design "chassis" (think the difference between HD600 & HD650 for example, there is no real physical design difference), but then you have things like unit to unit variation creating perceived differences, and also anything above 8000Hz which is not really measurable in a reliable fine-grained sense - you can measure the general energy up there but you can't use measurements to EQ it out to smooth treble above 8000Hz for instance, so that treble smoothness would be a defined characteristic of that headphone that can't be EQ'd out by the measurements. I think unit to unit variation is the biggest stumbling block for most headphones when using EQ, so that's why it good to buy a low unit to unit variation headphone, but some designs of headphone have large on head measured variation between different people (if you the measure the same unit on different people's real heads using in ear mics), so that's where earcup design comes into play because headphones like HD800 & K702 have been measured in some past studies as having low on head variation from person to person, so that's also a variable that will dictate how an EQ will sound, you'd want low on head variation between different people - and on this last point apparently the E3 has been designed to have lower on head variation than the Stealth for instance.
I finally bought an RME ADI-2 DAC FS to power the DCA E3 that is on the way!
Now, the RME takes a 6.3 mm (1/4") unbalanced plug, whereas the E3's cable has a 2.5 mm balanced plug.
Rather than spending €10-€15 on a plug adapter, I'm thinking of buying a second cable with a 6.3 mm plug since they're < €20 on AliExpress.
Has anyone tested such aftermarket cables for Dan Clark headphones? I know that all cables sound the same, but I'd like to make sure that they are well built, etc.
Thanks
I’ve just received my pair of e3 headphones today and have been shooting them out against the Austrian Audio The Composer.
Looking like I’m going to plump for the e3 but I’m finding my newly purchased amp doesn’t power them too well :(
The Composer headphones are 22 ohms and are fine with the Grace m900 but I have to turn the Grace up to around 80 (out of 100) to get any decent volume with the e3. That’s in high power mode I think but there doesn’t seem to be much difference vs low power mode. If the e3 are 27 ohms, shouldn’t they be easier to drive than the 22 ohms AA The Composer?
Thanks!
Thanks!
The sensitivity matters, not the impedance. The specs of the two are in different units, but the Composer is approx 96dB/mW and the E3 is approx 90dB/mW. So TC is going to be 6dB louder at the same power assuming I did the math right.
According to Amirm measurements, the E3 actual sensitivity is 84,1 dB/mW
