He has cheaper models, but what drives me crazy is that some reviewers call the E3 "mid-tier" and "affordable". Such a classification for a €2500 headphone would have been unthinkable when I joined the hobby 20 years ago.
Except he was talking about muddiness caused by the bass boost which I didn't equate as the same thing. What he was describing sounded like too much 100-300Hz, which I thought might be caused by harmonics from bass distortion because he listens at louder levels. The "soft bass" that I was describing, I'm not sure what exactly causes that in the HD800 for me, but I don't think it's distortion as I listen at low levels, so it's something else I think. But either way, what he was describing & what I was describing I see as two seperate things. I agree with what you say though re HD800 and "soft textured bass (as in not tight/punchy)".
Ok, I'm going to try to explain this the best I can, so please bear with me...
E3, no EQ vs HD800s (oratory Harman EQ preset) - not level matched, normal listening levels
Get Lucky - Daft Punk, Tidal - Roon - intro until Pharell starts singing
The bass on the E3 is balanced in the mix, best to describe it as a wall of sound with nothing standing out. On the HD800s the bass is a bit overwhelming in the sense it is not a wall of sound but there is a clear separation between the first and more distant second layer or plan. First is the bass and it's dominating the mix, everything else falls in the second layer/plan. So this actually isn't bass bleeding into mids, but a feature of HD800s being spacious and doing its own "sound presentation". Both are tuned to Harman, but they feel different.
E3 feels a little clearer, I think I can pick up subtle details more (like bass strings vibrating), but this could all be down to bias.
Royals - Lorde, Tidal - Roon - deep bass around 23 sec
Oh, how I hate this song. A similar thing is happening here, the bass is overwhelming and I feel like HD800s are struggling a little bit here as the bass is deeper IMO than in the previous song. E3 - effortless.
Angel (2006 remaster), Massive Atack - Tidal, Roon
Again, on E3 I just have a sense of clearness and effortlessness, but HD800s with a 5.5dB boost can BASS, don't get me wrong.
The mix is bad so can't pick up if there are any distortions just from headphones.
In conclusion, just by lowering the bass shelf to 3dB on the HD800s, I get the same feel - a more balanced mix. E3 is superb, but I'm honestly even more surprised by HD800s and how they hold up against more expensive, newer headphones. Tonally they are similar/same but the HD800s are presenting the music differently if that makes sense.
I didn't push the volume up this time.
Harman /oratory level bass boost on my 800 just does (edit NOT) sound right to me. Couple /three dB less sounds "right", with a corresponding dip around 200.Ok, I'm going to try to explain this the best I can, so please bear with me...
Are the pads on the 800s flattened by wear or ageing?
Harman /oratory level bass boost on my 800 just does sound right to me. Couple /three dB less sounds "right", with a corresponding dip around 200.
I'd love to try something like the high end DCA with that level of bass baked in.
Dammit. Does NOT sound right. The oratory for the 800 has something like 8db. Sounds far too wooly to me even after cut around 200Wait, does sound right or doesn't? The first oneYes, a 2.5 - 3dB boost instead of 5.5dB sounds right to me also.
Nice descriptions. As I was reading that I started to wonder if you're getting a proper seal on the E3? I say that because I never felt that "bass was dominating" in an Oratory EQ of HD800(s). Could it be you've got roll-off happening in the E3 with a less than perfect seal - so in other words maybe you just like less bass than Harman.Ok, I'm going to try to explain this the best I can, so please bear with me...
You could well be right re the effect of harmonic distortion in the bass, as I've not tested or experimented with it - I was instead just coming up with a theory that the harmonics would show themselves in the 100-200Hz zone thereby creating muddiness, but I can't say that with certainty because I've not knowingly experienced it or indeed experimented with it.IME adding harmonic distortion in the bass (so higher harmonics due to dynamic compression) usually does not lead to muddy bass but rather has the opposite effect on the lows. More harmonics lead to a 'tighter' bass experience in general.
Unfortunately, when this becomes severe enough to be audible the mids also become modulated by the bass in an unattractive and 'courser' overall sound.
It's the frequency response (correction) that leads to the 'muddy' bass IMO.
Getting EQ right for theHD800 on one's head is not an easy task. In any case.... bass is not the strong point of HD800 which is evident in all reviews out there.
It's best assets are excellent sound quality, comfort and imaging.... When you don't boost the bass too much the bass actually isn't bad though. Just not punchy.
It is good to hear E3 does that too (but just under HD800S it seems) and improves on bass (which is also important).
Still need to go and listen to one. Might be bad for my wallet....
That's good then. How about also just lightly pressing on the headphone cups whilst music playing to see if bass is enhanced? You wouldn't want to press too hard as it might be possible you'd get slightly more bass with increased pad compression anyway due to driver being closer to ear.I think I'm getting a proper seal. Did the test Dan posted for the seal and can't hear my fingertips rubbing together.
Edit: I don't have my HD600 with me (lent them to my father), but I'll try with them or with some other headphones (HD 419) to exclude the HD800s spatial thing.
You're likely not getting any bass leakage then, so we could say that you do like Harman Curve bass, which does make your HD800s experience interesting and unknown re muddiness with Oratory EQ to Harman. Like I say I don't get that same experience re HD800(s), just an impression of bass lacking some impact & definition (soft textured bass).E3 is a bit finicky with the placement, HD800 sounds the same no matter the placement.
For me, they work best when the ears are in the center of the pads horizontally, but pulled higher so that the pad touches the lower part of the ear and behind the jaw. The image is probably an exaggeration, but something like that (pulled up) works best for me.
No change in bass when lightly compressing pads.
Fair enough, is quite surprising you want to boost E3 further in the bass given what you said about HD800s, but you're right to adjust bass level to suit what sounds best.I think so, but I may just put a slight bass boost (like 1-2dB @90Hz) on E3 in Roon. Doesn't cost me anything and when changing from Sens to E3 I need to change the profile anyway. That will alleviate placing E3 in the same spot exactly every time.
Hi Solderdude, I've already replied to this message a few days ago, but I was just browsing the Sony MDR-7506 thread as someone new had replied there and I saw the following in Amir's review in his listening test:IME adding harmonic distortion in the bass (so higher harmonics due to dynamic compression) usually does not lead to muddy bass but rather has the opposite effect on the lows. More harmonics lead to a 'tighter' bass experience in general.
