An amplifier is both limited in voltage and current. Clipping behavior might be different from voltage clipping which is usually 'hard clipping'.
How an amplifier's current clipping behavior is depends on the circuit.
Can be clipping due to limited current perceived as bass roll-of or "thin" bass? I mean, lower frequencies usually louder in the music because of equal loudness curve, so they should be clipped first, right?
bass roll-off can be caused by either 2 things: Broken seal (not amp dependent) and subbass roll-off when using low impedance headphones.
The AEON 13 Ohm qualifies.
i believe this should not be the case, since portable amp output impedance specified as 0.21 ohm
