solderdude
Just curious, why do so many people build dedicated computers or pi's for their music if there is nothing wrong with using their main every day computer? And why do people buy better power supplies for their pi's or computers. Why do people concern themselves with these things...it seems that most people that are in this for a hobby do something to improve their sound, and almost everybody reports this, that, or the other thing, sounds better. Are all the people that have separate music computers or that use ethernet or bridges or spdif that think one things sounds better than the other are all just crazy. Personally, i think it is somewhere in the middle....but nothing dramatic, as many people proclaim.
People do that because they believe it makes a difference. When comparing sighted (knowing what they are using) this ensures confirmation and or incorrect results.
i just assume it is a noise issue if network sounds better than usb to me...but as others have stated, maybe it is my imagination....same goes with spdif too, that to me, it just sounds better.
When this is about truth-finding you need a bunch of specific conditions in place. Leave one out and the result is not about truth anymore but about favoring conditions. They so appear valid for the testers and ultimately base their choices on 'rigged' results. But when one doesn't mind I don't mind either. When one really wants to know the truth you can learn to do that here.
Nothing wrong when one likes to compare things without those controls in place when you are not trying to find out the truth but any 'test results' from such comparisons are null and void for most folks at ASR.
Also, as you have stated, Amir doesn't test everything, and there is likely some more sophisticated equipment out there that may show some things he does not test. Also no one fully understands human hearing... there are just so many variables and considerations. Even though i lean more toward objective measurements, I don't usually end up in one camp or the other......jmo...
Amir tests what he deems essential to test. You need specialized EMC equipment to perform valid/calibrated test results for EMC.
Even more expensive than an AP !
The fun part is that when one connects and sets up a hifi system properly with decently designed audio equipment there is no influence from the outside and performance is equal to the measurements done by Amir (or others).
The idea that 'we' can't test all electric parameters is complete BS coined by those that do not test properly and/or do not understand measurements.
There is no 'in between' in reality.
You either test correctly or you don't.
You can test correctly both by ear and/or measurements.
Do a half-ass job with either method and the results are flawed.
The most difficult part is to know when tests are done correctly and when they are not.
Those that have learned to test correctly will know when tests are done incorrectly (it is painfully obvious to them)
Those that do not know exactly how to test correctly and apply incorrect testing protocols (thinking they do it correctly) simply cannot fathom what is important and why their test results are flawed, despite these persons 'clearly' hearing it with night-and-day differences that they do not even have to test blind in their (flawed) opinion.
