Are there any DACS that sound as good hooked up to a daily use pc as being hooked up to a streamer?
I understand the concept of the streamer to isolate the noisy pc, but my thinking is that at a certain price point that a dac may be able to compensate for a noisy pc?
A: Some DACs do sound different and measure substantially different.
B: Amir measures S/N ratio and SINAD which both contain noise measurements
C: Depends on whether or not one uses a LOT of digital attenuation or not for noise to become audible combined with how loud the transducers an play.
Now DACs do not 'compensate' for a noisy PC.
The noise you are talking about does NOT originate from the DAC. Audibility of said noise (not the self noise of the DAC) depends on how the DAC internally is constructed. Some DACs are quite susceptible for common mode noises and there may be a few dongle or USB fed DACs that are not really well built and also may exhibit not so nice behavior when the 5V is too low and noisy but still too high for them to shut itself off.
Amir does NOT test for this. In order to get results that look very deep his test system must be connected as correctly as possible.
So now back to the (what I suppose is your question) the noise you speak of is common mode noise and is created by groundloops.
Groundloops exist in many forms and are sometimes difficult to debug.
I would guess that you have a groundloop somewhere.
What happens is common mode 'noise' travels along the input cable of the DAC. That noise is 'ignored' by the input of the DAC because as the name suggests it is
common mode. However, that noise is looking for path to travel through and picks the lowest impedance one.
Usually this means the mains or power connection but in some cases the audiopath is taken.
In particular the ground connection which is never a perfect 0 Ohm. In fact in some DACs there are small inductors, or ferrite beads, resistances inside. Also PCB design is very important here.
Anyways... that common mode current flows through the screen of the interlink and induces a small voltage. That voltage (as it is SE) then becomes audible. That is the noise/sounds/nasties one gets to hear in these circumstances.
Balanced connections can help here as the groundloop noise flows through the screen and not through the, intrinsically immune, balanced signal path.
Ways of stopping this from happening can include grounding, galvanic isolation of the source or other measures.
So yes.. there is a difference between DACs, signal paths etc. that in certain circumstances can make audible differences in noise levels that are not seen in Amir's plots nor in specs nor will these be present in systems of others. It could be the DAC manufacturers fault (poor design of grounding) or a design choice that doesn't pan out well. It could be the way the owner has connected everything.
One has to keep in mind that the
vast majority of DAC users do not experience these effects or it is below audible levels.
The behind lying reason is that not all DAC designers are equally savvy in designing equipment that also has to deal with common mode currents. I would almost say that such is a separate form of designing for it because you have to consider signal paths that aren't obvious.
You can test for this but haven't seen it done. The problem here is that while you can use test procedures that are standard there may well be different circumstances in ones home that differ from these tests and somehow still create audible 'nasties'.
This may be the case in OP's situation... or I am talking out of my ...
