DACs or DDCs with simultaneous concurrent outputs
john61ct
Looking to collect a list.
No need to post all the details, just list the inputs and which outputs are concurrent.
Compare / contrast features / SQ issues welcome if known to you.
Special Subset, devices that can act as DDC & DAC simultaneously.
Topping D10S and D10B, USB input only, outputs both S/PDIF types and analog, all three concurrently.
Blustream DAC12AU, both S/PDIF types - gives TOSlink priority. Outputs coax and SE analog concurrently.
Quloos qu02 DDC
I have had one for three years, no issues and not only does it have multiple concurrent outputs, it has two COAX so you can get identical output levels. USB input only
This is the manufacturers link
available at different outlets but onsale at shenzhenaudio at the moment.
Nice output list, I2S might come in handy!
Eitr 2 to compare has none, but is cheaper at $99 before the preamp upgrade.
SONCOZ LA-QXD1 DAC + DDC
32-bit/768kHz PCM and native DSD512 via the USB input
Inputs
USB-B gadget interface
RCA S/PDIF Coax
TOSlink
USB-C port for 5V 1A power input only
all outputs concurrent*
fully balanced analog XLR, 4.0Vrms
SE analog RCS, 2.0Vrms
S/PDIF RCA Coax (DDC passthrough, *but not from TOSlink from USB only!) SONCOZ SGD1 fixes that, for $500 8-(
$20!!
apparently "Tohilkel", many sources
192KHz Multi Function Audio Converter
All outputs concurrent
As DDC likely fine, but I find it hard to believe the DAC is OK?
Another with I²S output (Pro version) all the way up to 32-bit/768kHz PCM or DSD512
S/PDIF output 24-bit/192kHz PCM or DSD64 (via DoP
SMSL S.M.S.L PO100 Pro
DDC only, no analog Outputs
only input is USB XMOS, input only, one-way bridge, not PC interface
Digital Outputs, all concurrent
1x TOSlink
1x S/PDIF RCA Coaxial
UAC1/UAC2 switch for game consoles
different from PO100 non-Pro, or ΑΚ
Topping DX1 II
USB-C + TOSLINK inputs
has 10-bands PEQ !
HP amp with mic in! and remote
rear RCA & 4.4mm balanced line-out, and the front headphone jacks all play the same audio stream concurrently
unlike Topping D10s D10B, no S/PDIF Coax
but TOSlink DDC passthrough
can apply per channel EQ to the RCA / balanced pre-amp outputs, but disable EQ from being applied to the optical out
can configure the device to control optical volume or not
multi-channel DDC DAC + HPamp + pre-amp with pseudo "crossover"? (miniDSP 2x4)
relevant (inaccurate title!)
