KSTR
When your hearing stops at 20kHz, or much likelier way below 20kHz, that little bit of imaging is irrelevant to most anyone. You'd need pretty bad amps/speakers to run into any IMD issues larger that the normal IMD. The HF noise from aggressive noise-noise shaping for DSD (and derived PCM) is for sure the much bigger problem.What do we get for letting some imaging in ? what is worth the tradeoff . I don't think its explained at all in the tread .
It's been mentioned already, to find out what's going on, given the more like 16kHz top limit for most of us, we need to reduce sampling frequency to say, 32kHz or even lower and test different filters there.
When the input to an ADC is properly band-limited (both with analog and then with the digital filter before decimation), the DAC's reconstruction shall not add to the overall transfer function and it shall not add artefacts (new frequencies).. The only way to get there is the full sinc reconstruction. This reduces the lowpass function (and impulse response / ringing) to that of the ADCs filter. It cannot get any better than that. You need a steep filter here to avoid a lot of aliasing which would really corrupt the signal forever. It will have a lot of ringing, inevitably.
If the digital signal contains 'illegal' content, the full sinc will produce lots of ringing but of couse this is still correct as it reconstructs the signal that would have been needed as "equivalent analog input" after it has gone through all the ADCs anti-aliasing filters.
The whole idea of ADC-->DAC conversion is that -- for a maximised passband -- the unavoidable ringing at (or near) fs/2 is inaudible to begin with, being outside the human hearing range.
