DAC with 2 chips sound any better than a dac with only one chip ?
Earwax
Vancouver, Canada
Fosi audio DS1 USB-c dac has the same dac chip as the Topping D50 III I`m simply curious would I notice a difference in left and right speakers ?
I just bought the DS1 and very impressed...
Applications used with : A52 cellphone with USB Audio player Pro app to bypass Android garbage.
: Asus Desktop PC USB-C it worked simply plug and play no drivers needed, using Foobar2000 for best sounds Musicbee is interesting.
: Played through Harmon Kardon AVR 140 using CD RCA inputs that allow digital bypass with pure analog in stereo, Tone off. JBL Northridge series N28 speakers.
Seriously impressed played both above setups through AVR 140 I just can imagine it getting much better than this at least not cost wise... Unless 2 chips would make any difference ?
Thank you in advanced for your knowledge and fact sharing much appreciated !
no, it does not.
1 DAC chip or multiple, as long as DAC is properly designed (which you find from ASR reviews) they will have no “sound” differences.
In fact, DACs shouldn’t “sound” like anything…. as long as they are “transparent”.
Paralleling multiple DAC chips could make for better measurements, but it's not going to make any difference to the human ears. You might get a nice jolt of placebo, but nothing you could discern by sound alone.
Windows 11
Ahhh IC... Goody because PEQ solutions for Win11 are free to use and are very good tools. If you want PEQ and I highly recommend you do because it is a night and day improvement in sound quality then install the following 2 softwares in the order they are posted here and open the Peace EQ and adjust for your best sound quality. Disable the auto-updates in the Peace options window.
Here are other PEQ options but the stuff I recommend for you is the best of the choices for your needs.
I`ll be trying those installs as soon as I get time, then the fun learning begins. I have never learned how to use any EQ`s properly and I`m eager to learn.
Many thanks for all the guidance and knowledge.
Cool! The rubber really meets the road when you start taking measurements using REW which is also free. You check the sound in your room and it generates PEQ settings to fix the bass in your room automatically. Lots of tutorials around here. Check it out once you're feeling up to speed with Peace / EQAPO.
To use EQ properly you’ll need to learn how to take acoustic measurements with a microphone and derive necessary corrections from them. It’s easier for headphones as there’s no room as a variable, you can find reasonable EQ settings suggested by others for what you have that compensate for discovered deficiencies.
I only have 2 Headphones are you saying that each headphone my sound better across my mainstream musical Genres ? Or would I have to change it for each song ?
Audio technica ath-m50x wired
House of Marley Riddim EM-JH053
If the headphones (or speakers) are accurate, all music of all genres will sound "right" (as intended). But unlike electronics, you can't get "perfect accuracy" or transparency with headphones or speakers in a room.
Of course, not all recordings are "perfect", and different people have different tastes.
But to complicate things.... headphones are perceived differently than speakers and it turns-out, unlike almost everything else in audio, flat frequency response doesn't "sound right". There is a headphone preference curve which is essentially an average of what sounds right to most listeners.
When Amir tests headphones, he measures the frequency response and then creates EQ adjustments to better match the Harman target curve. The ATH-M50X is reviewed here. You can see how it compares with the target curve, and PEQ adjustments recommended by Amir.
With different EQ, different headphones can be made to sound similar, both close to matching the target curve. (There are limitations, and for example, if the headphone has weak bass, you may not be able to boost the bass to match the curve without distorting the headphone or headphone amp.)
Parametric EQ (PEQ) is more precise than regular graphic EQ so it's better for this purpose, or for fixing a particular problem. But it's harder to "play with" for everyday adjustments. If you like a little extra bass, that can be included in the PEQ, or you can use graphic EQ.
For those kind of everyday adjustments regular-old tone controls are the most convenient, physical knobs if you have them.
You apply a set of specific EQ corrections for each headphones, they will then sound better across all genres/songs. That said, you can of course further fine tune those corrections to your liking for a specific type of music, but the bulk of improvements should come from the main correction.
I did type in i just CAN`T imagine it getting much better...
With that said after room tuning using Parametric EQ I might eat that statement :]
I`ll be posting another thread for technical details about my AVR 140 and how it bypasses the digital as that combined with that very affordable usb dac and the App that bypasses android sound system just killed everything I ever heard before. So naturally I`m very curious about my Harmon Kardon.
Obviously I`m no Audiophile so don`t be to hard on me.
Few around here will describe themselves that way. We're hobbyists or enthusiasts.
No one's going to be hard on you for asking honest questions. People usually only get their backs up if you really dig your heels in on something that's been shown to be BS over and over and over again (like that DACs that measure transparent have a "sound", for example).
I post my question about my Harmon Kardon AVR 140 Pure Direct Mode ( Digital Bypass to Pure Analog ) in the Audio Electronic & Hardware category figured people in that arena would have the raw core functionality understanding... ?
