macauley86
- Joined
- Oct 8, 2019
- Messages
- 42
- Likes
- 60
My music library is ripped from CDs at AIFF 44.1 kHz sample rate, playing on a 2013 MacBook Pro running Audirvana through its internal DAC connected to my integrated amp via 3.5mm-to-RCA. I'm also testing a Topping D10 USB DAC with the system.
Is it best practice to disable upsampling in Audirvana, thus using the 44.1 kHz sample rate that matches my source material? Or should I upsample using the power of 2, 4, 8? Or upsample to the DAC's native (max) resolution? Or does it not matter? I have read that upsampling buys you nothing and could introduce quantization noise.
Any advice?
Any advice?
