DAC to connect Sony TV to JBL 305P Mk2
yabadaba
Hi, my son gave me a pair of JBL 305P MK2's and I want to use them with my Sony X95J TV until I get a proper home theatre system. I've tried connecting via optical to a Schiit DAC I already have that has XLR outputs and it works BUT the only way I can control volume is via the speakers themselves, or in an optical output level setting that is buried deep in the TV menu. So, what I want is a DAC that has XLR (or TRS) outputs and a pre-amp function with volume adjustable via the remote control. I can see Topping has a few options but all seem quite pricey for an interim solution. Any recommendations?
staticV3
The SMSL D-6 is probably the least expensive DAC with TRS Bal out and a remote. It costs $170.
MCH
I am selling a topping D30pro that can do what you need and has one of the best SNR in its class. But you need to know that toslink in is a gamble with topping. I think it is ok with tv but not 100%sure.
Blumlein 88
Is it possible to maybe get a universal remote that can access the volume on the TV directly without going into menus?
Blumlein 88
Looking at the manual it appears in settings you can select fixed or variable volume. Selecting variable lets you control the volume via the remote. However it isn't clear if this also controls the volume over optical or if optical is still fixed. Just a thought if you haven't tried this.
Y
yabadaba
Hi, thanks. I'm familiar with the kind of setting you refer to, but can't see that in the audio or audio output menus on this TV.
