Firulais71
- Joined
- Dec 24, 2025
- Messages
- 47
- Likes
- 32
Greetings, friends. I was going to buy a pair of Fosi V3 Mono speakers to set up a sound system for my TV and music room, but I've decided to use one of the old amplifiers I have in storage. From all the vintage gear, I'll use:
Yamaha AX-497 amplifier, specifications:
- Power output: 85 watts per channel into 8Ω (stereo).
- Frequency response: 20Hz to 20kHz.
- Total harmonic distortion: 0.009%.
- Damping factor: 240.
- Input sensitivity: 2.5mV (MM), 150mV (line).
- Signal-to-noise ratio: 88dB (MM), 110dB (line).
- Channel separation: 50dB (line).
- Output: 195mV (line). - Tone control: Bass: ±10 dB at 20 Hz / Treble: ±10 dB at 20,000 Hz.
- Loudness: adjustable.
- No high filter, no low filter (Subsonic).
The amplifier belonged to my father, and apart from a slight dent on the top of the metal casing, the unit is in excellent working condition. The inside is immaculate; I opened it up and it looks brand new. My father used it very little, maybe a couple of years, because when he changed turntables he bought a Marantz PM-94 amplifier, and the Yamaha went into storage along with other equipment.
I never found the Yamaha remote control, but I've already ordered a compatible one from AliExpress.
The speakers I'll be using are Onkyo E-83A MkII speakers manufactured in 1973. Specifications:
- Class: 3-Way, airtight type (sealed).
- Units Used: for low band 30 cm Cone Type (W-30AmkII), for middle range horn type (HM-500AmkII), for high range horn type (TW-9A).
- Playback frequency band 30 Hz to 20 kHz.
- Rated input 30W.
- Max Input 60W.
- Impedance 8 Ω.
- Output sound pressure, between 98dB/W and 99dB/W.
- Crossover frequency 700 Hz, 5 kHz (12dB/oct.).
- Cabinet internal volume 80L.
- External dimensions: Width 420x Height 720x Depth 390 mm.
- Weight 23kg.
I've been testing the speakers with the amp for several days and the sound is incredible, wonderful for jazz, classical, opera, country, guitar/piano solos, wind instruments, pop, and vocals in general. The bass is crisp, punchy, and deep in your gut. They might not be the most rock-oriented (boomy) bass, but they're perfect for what I listen to. It creates a great soundstage, and the amp is robust enough to drive the Onkyo speakers with authority. There's zero clipping; you can tell they have plenty of power, good headroom. To test the equipment, I used a connection between my laptop's headphone output and the amp's CD input. I know it's not the ideal connection, but it worked for the functional tests.
For the final setup, I'll be playing the music on a mini PC with Foobar or Roon, with all the files in FLAC and SD formats. So, I'm missing a DAC, for which I plan to spend a maximum of $180-$200. I was thinking about the Fosi ZD3 or even an SMSL SU-1, which I've read very good reviews about. While I know they're very affordable DACs, I honestly don't think I need anything more powerful.
¿What affordable DAC would you recommend to complete the setup?
Best regards.
- Rated input 30W.
- Max Input 60W.
- Impedance 8 Ω.
- Weight 23kg.
Best regards.
