DAC or streamer combo advice
GVW
Hi guys,
Please looking for some advice here.. Running my Melody Pro88MK2 into my AudioSolutions speaker via Wiim Ultra to Schiit Mimir.. I am now ready to invest and get rid of weakest link here..
I believe this to be the digital to analog section...
Am thinking to go for a sole DAC ( Denafrips, Gustard etc) and use the Wiim Ultra just as a music transport from the iPad to the DAC.. Or get rid of it all and go for a streamer /dac combo such as Evernote A10, Gustard D26 II X30, HifiRose, etc etc...
I have the feeling that If i spend 3K on a sole DAC i have less compromise and more bang for the buck compared spending 3K on a streamer combo that is ussually also a pre amp which I dont need ....
Or will the Wiim Ultra just as digital transpoer ( via USB) will for sure be the weakest link and takes the quality of the sole DAC away??
Thank you for your attention and your answers to help
Hi @GVW! Welcome to ASR.
The WiiM Ultra is a fully transparent Streamer and DAC and as such, is the strongest link that money can buy (difficult to accept, I know):
If you want to invest 3K in better sound, then the best way to achieve that is to buy a measurement microphone for room correction, some subwoofers, new speakers, or room treatment.
The Tube Amp is likely a bit of a distortion generator as well.
Indeed:
2 X 50 Watts
THD 1%
SNR >88dB
Hmmmmm... So the Pro88MK2 (which was a 4K euro amp) is then the weakest link here you guys say....?? Ive invested also in PSvane Summit valves ... WOuld be a bummer to realise this fact... How do you know that it will bring distortion by looking at these nrs? Are they to low , to high ? Sorry for asking . ..
Too low power and too high distortion. A Wiim Amp Ultra would be a much better solution for 10x less money
That's what modern Tube Amps do:
You buy them for nostalgia or the subtle sound effect that the raised distortion of vacuum tubes makes.
You don't buy them for transparent audio reproduction.
Changing the valves is not needed, and may make it sonically worse if there are slight changes in bias needed to suit the new valves - different brands are not perfectly interchangeable. I don't know about hifi valve amps, but generally, guitar amps don't seem to have auto-bias and often need a bias check.
I'm sure the amp sounds perfectly good, but most likely at lower volumes and so long you don't need serious bass. As said, by modern standards you can get get better numbers and more features for 1/10th of the price now, including a "better" DAC.
If you have not already found and implemented your solution… Is there something about the sound of your setup you want to change/fix? Looking at your digital DAC and streamer, those should sound pretty good, no? It is true that amp would add some distortion and flavor to the sound. Do you not like the sound of it? What is missing in what you have now?
Well... ive bit a first of many bullit.. and bought myself an amazing piece of kit ; IOM Metric Stereo..
Hand built by proper audio guys im Holland folliwing the Hypex design..
The difference in sound is now already crazy compaired to the tube amp... ; speakers have come alive and now really sing !!
I might be thinking the speakers are OK now as they dont sound so slow, sluggish and wooly anymore.
Although I will be aditioning Elysium 1/R1, Canton Reference 9 and Borresson X1 in few weeks...
My main focus is now on the 'weakest'link and that is in my ideas the WiiM Ultra via USB to Schiit Mimir ... Although they are OK.
Im sure I can get a lot more out of the system..
Thinking ;
Topping D900
Gustard R26 II
Eversolo A8 Gen 2
With the first 2 ill have to keen toe Ultra for now as streaming duties..
With the Èversolo A8 i dont...
Whats very important is the pre amp stage that needs to be seriously good !!
SHOOT !!
Thinking ;
Topping D900
Gustard R26 II
Eversolo A8 Gen 2
SHOOT !!
The WiiM is a fully transparent DAC+Streamer and as such no improvements in sound quality can be had there, besides imaginary ones from expectation bias/sunk cost fallacy.
As you've already taken two steps into engineering-focused HiFi with the WiiM and IOM, and with great results it sounds like, I'd suggest you give the speakers the same treatment.
That would mean certainly skipping Borresen, who produce offensively bad speakers: https://www.erinsaudiocorner.com/loudspeakers/børresen_x3/
For well engineered loudspeakers, have a look at:
KEF
Revel
Arendal
Ascilab
MoFi
Magico
Perlisten
GGNTKT
Kii Audio
Philharmonic Audio
Ascend Acoustics
Buchardt Audio
In staticV3’s list I am partial to the last three since I currently have Philharmonic BMR monitors, have tried Ascend Sierra v2 towers in my room and almost went with a pair of Buchardts. Any speaker from that list deserves consideration.
KEF
Revel
Arendal
Ascilab
MoFi
Magico
Perlisten
GGNTKT
Kii Audio
Philharmonic Audio
Ascend Acoustics
Buchardt Audio
thx for that!!! What you think about the new Wharfedale Elysium 1 and R1..? Or Canrom Reference 9?? My local dealer has these in stock so can audit these... And do a part exchange deal moving the Audio Solutions Overture back to them as part payment......
Absolutely is.
There's no measurement data on the two Wharfedale models.
The Canton though is a clear step below loudspeakers from the brands listed above:
It's a typical showroom tuning, designed to dazzle first time listeners into a purchase.
About 5 years ago (6?) I bought an all-in-one DAC/streamer/amp under WAF pressure.
It has been excellent for our use, but it is now longer supported software-wise. This means if any of the built-in streaming apps needs an update, it won't happen. This is no problem for me as I only use for DLNA (local streaming from my RAID box), but could be a problem for those with internet subscriptions. So the software could make perfectly good hardware obsolete.
Since I bought the unit, there is now a ton of sonically brilliant kit available at great prices. A streamer that includes a DAC is now so good, and so cheap, I'd not worry about replacing it when the software updates stops, annoying and wasteful as that is. But I lean towards at least having a separate amp - I may move house and get bigger speakers in a bigger room and need more power than my 75W Hypex can provide (it's more than loud enough with my current speakers and my current room).
So my advice would be to buy a good value streamer-DAC, and focus on the features and UI (the audio figures will be fine), no need to have seprates there, and a nice Class D amp (Hypex or Purifi if you want a lot a power, but chip ones are fine). I'd say say listen to as many speakers as possible and spend whatever it takes to get the sound you like.
If you like the distortion tubes deliver, that's just a matter of taste.
IMO over half the total system cost should remain in the speakers as you spend more.
But if you have no measurements driven DSP DRC that will give huge bang for the buck improvements
That IOM Metric amp looks really nice. A new company to me. Lots of power! I thought my 450wpc into 4ohms was a lot!
Its an amazing company!! Also check out the mono blocks with the VU meters!!
