- Thread Starter
- #161
Mani, as I mentioned before, non-linear EQ is designed to eliminate the differences in the null caused by filters or other, consistent frequency response differences between two waveforms.
Thanks Paul. Good to know that I'm correct in not applying any of DW's EQ.
But my post was really in response to this:
Having now seen the length of this file, as Paul already suggested, you'll get better results with a longer piece of music to work with. 30 seconds is near the lower end where Deltawave works well. After using it quite a bit I don't bother with less than a minute. 2-4 minutes is optimum I think.
Edit: I purposely used the full track of >3.5 minutes in my post: https://audiosciencereview.com/foru...asurements-using-deltawave.59822/post-2194642
DW works perfectly well with my reference track of 30 seconds, as I have no need of clock drift correction or EQ.
