DAC listening test files - updated with new filters files
Hi Pavel, was this generated as a periodic (FFT) white noise or "pure" white noise? When I listen to the reference white noise, I hear periodicity in it that shouldn't be there, perhaps 1 second or so?
This is the clue why I hear it easily. It shouldn't be so easy.
Periodic. You can see periodicity in the time plots in your DW.
Yes, I know. But R and L differs in period.
No. One is built from another. They are time shifted. And one is LPF filtered to get 20kHz drop.
I meant time shifted, not period. So I hear that. Se the time-stamp from the Lacinato. Very different there.
I'd say 0.5 second. To me it sounds like air conditioning or dehumidifier unit that has some kind of resonance. I play B (Rwhite.wav) and count "one, two, one, two, ..." and then switch to X on "two". If the count goes on uninterrupted, then X=B. If there is slight delay, then X=A.
foo_abx 2.2.1 report
foobar2000 v2.24.5
2026-10-16 23:03:38
File A: Lwhite.wav
SHA1: ae7f9725e87abb47f717b63b49dedd3a9b838416
File B: Rwhite.wav
SHA1: 23f9d0e148b4fd7436d713fea21ecbf1da5d86d2
Output:
Default : Speakers (FiiO K3) [exclusive], 32-bit
Crossfading: NO
23:03:38 : Test started.
23:03:50 : Test restarted.
23:03:50 : 01/01
23:03:59 : Test restarted.
23:03:59 : 02/02
23:04:07 : Test restarted.
23:04:07 : 03/03
23:04:11 : Test restarted.
23:04:11 : 04/04
23:04:21 : Test restarted.
23:04:21 : 05/05
23:04:31 : Test restarted.
23:04:31 : 06/06
23:04:37 : Test restarted.
23:04:37 : 07/07
23:04:42 : Test restarted.
23:04:42 : 08/08
23:04:46 : Test restarted.
23:04:46 : 09/09
23:04:53 : Test restarted.
23:04:53 : 10/10
23:05:02 : Test restarted.
23:05:02 : 11/11
23:05:14 : Test restarted.
23:05:14 : 12/12
23:05:14 : Test finished.
Total: 12/12
p-value: 0.0002 (0.02%)
-- signature --
40768306973d2b3af4496fd4120bc1003a251b69
To me, the quick periodic "click" in white noise obscures other artifacts that might be there. I find it hard to focus on anything else when I hear it. Maybe I should try non-periodic white noise...
You are of course free to use your own generated “random” white noise sample. Below the comparison of both. Note - AI generated.
I assume the one you were using was generated by REW? I'm just curious where the audible periodic artifact is coming from. Multitone implemented periodic (FFT-based) white noise from the beginning. When I use Multitone, I don't hear the same periodic pattern in playback. Here's the Multitone-generated WAV with periodic white noise (FFT=128k). Does it have an obvious periodic component to it?
https://app.box.com/s/0v8adg2oioqhf2s3jj1civ0zc62d4h50
And here's the spectrum of this file without an FFT window, demonstrating some of the points that AI made in the summary you posted :)
Your link is somewhat broken. The text of the link is the address, but the actual address in the URL tag is a copy of your previous text:
Code:
[URL='http://I assume ... an FFT window:']https://app.box.com/s/0v8adg2oioqhf2s3jj1civ0zc62d4h50[/URL]
There many ways, including different periodicity, to generate PRN.
I was traveling the end of last week and the weekend so just now trying Paul's ripple test (music, not noise). I compared 0.5dB and 0.025dB and it seems I can tell the difference. I will try again later to make it more of less clear whether I was just lucky. I think it is hard to hear a difference.
foo_abx 2.2.3 report
foobar2000 v2.25.10
2026-10-19 07:27:11
File A: dactest_ripple 0_5db.wav
SHA1: 7080d1d5c18de5f1e628426ee6163b2e29ba7499
File B: dactest_ripple 0_025db.wav
SHA1: 699a5c99c19e6566a0b8eb4d739f9f4a76775d0d
Output:
Default : Headphones (Realtek(R) Audio) [exclusive], 24-bit
Crossfading: NO
07:27:11 : Test started.
07:27:52 : Test restarted.
07:27:52 : 00/01
07:28:18 : Test restarted.
07:28:18 : 01/02
07:28:39 : Test restarted.
07:28:39 : 02/03
07:29:22 : Test restarted.
07:29:22 : 02/04
07:29:43 : Test restarted.
07:29:43 : 03/05
07:29:57 : Test restarted.
07:29:57 : 04/06
07:30:14 : Test restarted.
07:30:14 : 05/07
07:30:30 : Test restarted.
07:30:30 : 05/08
07:30:43 : Test restarted.
07:30:43 : 06/09
07:31:16 : Test restarted.
07:31:16 : 07/10
07:31:29 : Test restarted.
07:31:29 : 08/11
07:31:42 : Test restarted.
07:31:42 : 09/12
07:31:55 : Test restarted.
07:31:55 : 09/13
07:32:12 : Test restarted.
07:32:12 : 10/14
07:32:27 : Test restarted.
07:32:27 : 11/15
07:32:37 : Test restarted.
07:32:37 : 12/16
07:32:37 : Test finished.
Total: 12/16
p-value: 0.0384 (3.84%)
-- signature --
dc5426066069f02d3409171ef946f9f8b46e72e0
foobar2000 v2.25.10
2026-10-19 07:27:11
Output:
Crossfading: NO
07:27:52 : 00/01
07:28:18 : 01/02
07:28:39 : 02/03
07:29:22 : 02/04
07:29:43 : 03/05
07:29:57 : 04/06
07:30:14 : 05/07
07:30:30 : 05/08
07:30:43 : 06/09
07:31:16 : 07/10
07:31:29 : 08/11
07:31:42 : 09/12
07:31:55 : 09/13
07:32:12 : 10/14
07:32:27 : 11/15
07:32:37 : 12/16
Total: 12/16
-- signature --
Thank you! We have a confirmation that 0.5dB ripple is audible with music.
I am working on improvements to the DAC/ADC loopback method. It starts to be more and more obvious that the DACs under test must be driven simultaneously by the same digital signal and their outputs must be recorded simultaneously. This is the only way to avoid random errors. So, the test files will be monophonic. Maybe it is even better for precise matching. The DACs will be driven simultaneously and exclusively via optical fibres, to avoid all non-DAC related errors.
This will give better numbers in DeltaWave, but does it really matter? I am asking, not trying to be in disagreement. What errors besides clock drift would be removed by the simultaneous recording compared to separate recordings? Does minor timing difference affect ABX in Foobar2000?
It seems that some people, such as Josh, rely on using recordings that they know very well for comparing DACs. So I think they would want stereo.
I like the idea of doing this, though, for the sake of seeing what level of nulling can be achieved this way.
I've done this a lot with the help of RME ADI-2 Pro (and 2/4 Pro SE) where the clock can be synched to an external clock (for example, DAC or external clock source) using SPDIF while using ADC to capture the signal. Works well.
If you guys still have some patience with me, I would be grateful if you tried these 96/24 test files:
to check my new loopback method. Many thanks!
If you still want to try, I just uploaded a 1dB ripple applied to that same 96k reference:
https://app.box.com/s/sdqusrud8faa4e025lsl9dt1n1bzj16z
I've managed to produce some results for 1 and 0.5 dB ripple with the 96 kHz files:
Test fileCorrect guessesp-value
dchesorig1_ripple 1db.wav14/160.21%
dchesorig1_ripple 0.5db.wav27/401.9%
In the last test for 0.5 dB I managed a 7/8 (p=3.5%), so I may have zeroed in on a stronger clue there. Or I was just lucky. In the other 0.5 dB tests I struggled quite a bit while 1 dB was pretty easy. I hope to find the time and motivation to try out 0.25 dB in the coming days. I would expect that to be very difficult, though.
