Yes, 0.5dB is the documented winner so far. It is interesting that the ripple is audible in the first place, and a 0.5dB ripple is audible with music. Not an obvious result and is worth checking in DAC filters before deciding that one is fully transparent.To me, 0.5 dB is a documented limit in Paul’s test. I saw some results at AS, but those are not supported by any test report.
That’s also an important result, thank you for doing the test!Nada for me here, E-MU and old (and I mean old) AT M-ATH2 irons everything out, I could try with LCD-X as well but it felt meaningless![]()
Would it make sense to apply ripple filter to white noise and test? I’d assume that would make it easier to detect.I am more curious why I heard differences in white noise here.
Audio by Van Alstine ABX Comparator Review
All the drama aside, Josh put as much work into this test as I've seen outside of actual scientific studies. Which I guess exposed him to the sunk cost bias, cos getting this type of very weird results and prioritise the explanation that ''I can tell 2 Dacs appart'' shows a lack of common...www.audiosciencereview.com
I should not hear that according to my ear status. What is it that I hear then?
I do not know what test signal would be easiest to detect for ripple. But I would stretch it to use also test signals - if it is detectable with test signals you can never exclude that it is not audible with music, since music is so variable. My question regarding the white noise test files that @pma delivered was the 0.5 dB difference at 20 kHz (and ≈0.2 dB at 10 kHz), is that really audible? I was on the impression that 10 kHz level JND is around 1 dB.Would it make sense to apply ripple filter to white noise and test? I’d assume that would make it easier to detect.
I’d assume that 0.2dB at 10kHz might be audible with white noise, and more so if your ears are fairly young, as you’d get to hear further up in the spectrum. Having equal energy at all frequencies is not something one would generally experience with music, plus our brains are much better at picking up anomalies from noise than from complex sounds which is why noise is a more sensitive test signal.I do not know what test signal would be easiest to detect for ripple. But I would stretch it to use also test signals - if it is detectable with test signals you can never exclude that it is not audible with music, since music is so variable. My question regarding the white noise test files that @pma delivered was the 0.5 dB difference at 20 kHz (and ≈0.2 dB at 10 kHz), is that really audible? I was on the impression that 10 kHz level JND is around 1 dB.
My ears are not young any longer so I would not expect a JND of 0.2 dB at 10 kHz with white noise. 1-4 kHz yes, but not 10 kHz. So that was a bit surprising to me and makes me wonder - many slow filters would be quite audible.I’d assume that 0.2dB at 10kHz might be audible with white noise, and more so if your ears are fairly young, as you’d get to hear further up in the spectrum. Having equal energy at all frequencies is not something one would generally experience with music, plus our brains are much better at picking up anomalies from noise than from complex sounds which is why noise is a more sensitive test signal.
I can hear it as emphasized bass amplitude. Please note the ripple plot I posted earlier, 20Hz - 400Hz is elevated of almost 0.1dB. For the reason of FR ripple, perfect level matching is impossible.Yes, 0.5dB is the documented winner so far. It is interesting that the ripple is audible in the first place, and a 0.5dB ripple is audible with music. Not an obvious result and is worth checking in DAC filters before deciding that one is fully transparent.
That would be really easy to test when one has a DAC with filter options and a good ADC.My ears are not young any longer so I would not expect a JND of 0.2 dB at 10 kHz with white noise. 1-4 kHz yes, but not 10 kHz. So that was a bit surprising to me and makes me wonder - many slow filters would be quite audible.
Still on the limit with 1 dB
foo_abx 2.2.3 report
foobar2000 v2.25.10
0126-10-16 18:50:51
File A: Lwhite.wav
SHA1: ae7f9725e87abb47f717b63b49dedd3a9b838416
File B: Lwhite_ripple 1dB.wav
SHA1: b017fb7949e66c73b452ad106095c4a5f13d9f75
Output:
Core Audio : Default, 24-bit
Crossfading: NO
18:50:51 : Test started.
18:52:29 : Test restarted.
18:52:29 : 01/01
18:52:40 : Test restarted.
18:52:40 : 01/02
18:53:02 : Test restarted.
18:53:02 : 02/03
18:53:17 : Test restarted.
18:53:17 : 03/04
18:53:30 : Test restarted.
18:53:30 : 03/05
18:53:50 : Test restarted.
18:53:50 : 04/06
18:54:00 : Test restarted.
18:54:00 : 05/07
18:54:11 : Test restarted.
18:54:11 : 05/08
18:54:25 : Test restarted.
18:54:25 : 06/09
18:54:40 : Test restarted.
18:54:40 : 07/10
18:54:59 : Test restarted.
18:54:59 : 08/11
18:55:10 : Test restarted.
18:55:10 : 08/12
18:55:30 : Test restarted.
18:55:30 : 09/13
18:55:43 : Test restarted.
18:55:43 : 10/14
18:55:55 : Test restarted.
18:55:55 : 11/15
18:56:03 : Test restarted.
18:56:03 : 12/16
18:56:14 : Test restarted.
18:56:14 : 13/17
18:56:28 : Test restarted.
18:56:28 : 14/18
18:56:47 : Test restarted.
18:56:47 : 14/19
18:57:20 : Test restarted.
18:57:20 : 15/20
18:57:20 : Test finished.
Total: 15/20
p-value: 0.0207 (2.07%)
-- signature --
751dd3f126acaf08a1201f73003af482247e6793
There is a slight shift in timbre. Would be interesting with more people testing.Sounds like that may be the lower limit for you and your equipment. Is there some specific difference that you're focusing on?
Hi Pavel, was this generated as a periodic (FFT) white noise or "pure" white noise? When I listen to the reference white noise, I hear periodicity in it that shouldn't be there, perhaps 1 second or so?However, this one was easy for you, right?
